vizio
+ More Options
Posts
  • markmac3
    • Sep 2017
    • 22
    Re: vizio
    Originally posted by budm
    Right now Op has no PS-ON so there will be no 12V to test.
    12vdc testing: disconnect the 12vdc TV load from the power supply board and attach one #1157 (using
    just the Hi filament), the 12vdc output should stay at 12v (+/-1v), if not, the power supply has regulation
    problem.
    i unplugged the t-con board from main board, hooked up the 1157 bulb to 12v pin next to ps_on. pushed power button , no light. is this right?
    • markmac3
      • Sep 2017
      • 22
      Re: vizio
      I just tried this. I found one of the voltage reg that had 3.3v and jumped it to the ps_on. light came on, had 12v.
        Re: vizio
        As I indicated, your main board is not sending the PS-ON to turn on the power supply, so you need to find out why it is not sending the PC-ON. You can start by testing all 3 legs of all the Voltage regulator on the main board.
        BTW, jumping the PS-ON directly to the power source with out using current limiter resistor is not good idea, especially if you did remove the PS-ON wire going back to the main board first which you can damage the switched Transistor that controls the PS-ON signal line.
        You should also use low beam of the 1157 so you will reduce the inrush current, if you check the cold resistance of the 1157 filaments, you will find that it has very low cold resistance that can easily overload the power supply or damage it. You can easily calculate what the inrush current will be using Ohms law.
        • markmac3
          • Sep 2017
          • 22
          Re: vizio
          this was all the voltage regulators I saw on main board and there readings
          u11 no voltage on any leg
          u9 in 4.9 out 2.5 gr 1.2
          u8 in 2.5 out 1.2 adj 0
          u2 in 4.9 out 3.3 gr 2.0
          u5 in 4.9 out 2.6 gr 1.3
          and the ps_on wire was still on when I tried the jump.
          • markmac3
            • Sep 2017
            • 22
            Re: vizio
            I found a total of 7 voltage regulators on main board. 6 had the 1.25v between adjust pin and center pin and the correct voltages on the output (+1.25v). the one that did not read any voltage is different(bigger) than the others. theres 5- 1117, 1- 7805 and 1- 1084. the 7805 did not read any voltage on any pins. the other day when I jumped the ps_on,(and have not done that again) I did have voltage on that regulator, 12v in 4.9 out is what I remember. what would be my next step?
            • markmac3
              • Sep 2017
              • 22
              Re: vizio
              I saw the post from retiredcaps on how to display my readings from voltage regulators. I hope this is correct. all look good except U11. is it bad? also cant find datasheet for U9, I cant get a clear picture to show but the only other markings a what looks like a backwards C with 2 dashed lines vertically through the C and 2 vertical dashed lines to the right of the C.
              U11
              7805CT
              AMK 805G
              pin 1= 0v
              pin 2= 0v
              pin 3= .270
              U4
              AMC1117
              F0838G
              pin1 = 2.076
              pin2 = 3.336
              pin3 = 4.960
              U9
              1084
              0810EL
              pin 1 = 1.256
              pin 2 = 2.508
              pin 3 = 4.917
              U8
              AMC1117
              F0838G
              pin 1 = 0
              pin 2 = 1.261
              pin 3 = 2.508
              U2
              AMC1117
              F0838G
              pin 1 = 2.050
              pin 2 = 3.307
              pin 3 = 4.916
              U5
              AMC1117
              F0838G
              pin 1 = 1.383
              pin 2 = 2.647
              pin 3 = 4.905
              U7
              AMC1117
              F0838G
              pin 1 = 2.082
              pin 2 = 3.341
              pin 3 = 4.919
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                #27
                Re: vizio
                your vr's are good. you can not consider u11 bad as it does not receive any voltage.
                WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                • markmac3
                  • Sep 2017
                  • 22
                  Re: vizio
                  What would be my next step, kinda stuck on what to check.
                    Re: vizio
                    So right now we are dealing with the original boards. What do you get as far as the Voltages and the PS-ON if you install the replacement main board you bought?
                    BTW on post #17, you indicate of having 3.3V at the power switch, but does it change state when the power switch is activated?
                    • markmac3
                      • Sep 2017
                      • 22
                      Re: vizio
                      the readings are from the replacement boards. on the power switch I am getting 2.3, not 3.3 as I had posted. not sure if that's a typo, but I am getting the 2.3 volts back to the board on J6 pin 8. J6 goes to power switch,volume,source..etc, but no voltage on ps_on when power switch is pushed
                        Re: vizio
                        What happen if you use the remote to turn on the TV? We want to make sure it is not the power switch problem, to have two main board acting the same way is odd unless the replacement board is also bad.
                        • markmac3
                          • Sep 2017
                          • 22
                          Re: vizio
                          I get the same results using remote. I checked the pins on the remote sensor which is hooked to the power switch board. had 3.9v on one pin, it would drop the voltage when pressing the remote power button, nothing stable to read but it got no lower than 3.3. also checked J6 and on pin 5 it had the voltage drop like the remote sensor
                          • markmac3
                            • Sep 2017
                            • 22
                            Re: vizio
                            Just got another Tcon board,and like the Bob Segar song, still the same. I unsoldered all caps, one at a time, to check, found a couple out of the 10%range, replaced them and still nothing. Thanks budm an ivtec for your help really appreciate it.
                            • cheeky2
                              by cheeky2
                              05-25-2024, 03:27 AM
                            • Dani_2024
                              by Dani_2024
                              10-28-2024, 05:06 PM
                            • gavric
                              Vizio M70-C3 Half picture is bad, main board on its last leg?
                              by gavric
                              Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                              When tv powers on vizio V logo shows nice on whole screen. picture 1
                              When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                              When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                              When i click video to start playing picture goes black(like when you change...
                              09-02-2021, 08:55 PM
                            • fharris1977
                              Vizio D50u-D1 Dead: PSU or Main Board?
                              by fharris1977
                              Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                              03-12-2024, 12:22 PM
