Sharp Aquos LC-60LE640U Won't turn on
    Re: Sharp Aquos LC-60LE640U Won't turn on
    OK, that PD connector, it looks like pin 1 is on the far left (the picture is not really clear), if that the case, those exposed pins on the top side of the board are the ODD NUMBER pins (1, 3, 5,...)
    The EVEN NUMBER pins you will have to poke from the backside of the connector.
    • StodgyWaif
      • Apr 2014
      • 40
      Okay here is the corrected table:
      Pin# - Standby - Power On - Description
      01 - 11.99 - 11.98 - PNL12V
      02 - 11.97 - 11.98 - PNL12V
      03 - 00.00 - 00.00 - GND
      04 - 00.00 - 00.00 - GND
      05 - 13.05 - 13.07 - UR13.2V
      06 - 13.05 - 13.07 - UR13.2V
      07 - 13.05 - 13.08 - UR13.2V
      08 - 13.05 - 13.08 - UR13.2V
      09 - 00.00 - 00.00 - GND
      10 - 00.00 - 00.00 - GND
      11 - 00.00 - 00.00 - GND
      12 - 00.00 - 00.00 - GND
      13 - 03.29 - 03.29 - AC_DET
      14 - 02.84 - 02.84 - PS_ON
      15 - 05.02 - 05.03 - BU5V
      16 - 03.28 - 03.29 - PNL_POW
      17 - 00.00 - 00.00 - PWM1
      18 - 03.28 - 01.45 - NC
      19 - 00.57 - 00.00 - DIMMER
      20 - 03.28 - 01.45 - NC
      21 - 00.86 - 01.45 - OFL
      22 - 00.00 - 00.00 - ERROR
      23 - 00.00 - 00.00 - PWM2
      24 - 03.26 - 00.00 - STB
        Are you sure the readings are correct?
        For example:
        24 - 03.26 - 00.00 - STB This is the BL-ON signal which should be >2.5V when TV is turned on and < 1V when TV is turned off.
        Some of the command signals also do not toggle HI or LO when TV is ON/OFF.
        It does look like your main board is stuck in steady state.
        • StodgyWaif
          • Apr 2014
          • 40
          For example:
          Okay maybe I have misunderstood the term standby. Here is an updated table. If any readings seem wrong I will double check them for you:
          Pin# - Standby (Plugged in but turned off) - Power On (Right after plugging in) - Power On (After 15+ sec) - Description
          01 - 00.00 - 11.99 - 11.98 - PNL12V
          02 - 00.00 - 11.97 - 11.98 - PNL12V
          03 - 00.00 - 00.00 - 00.00 - GND
          04 - 00.00 - 00.00 - 00.00 - GND
          05 - 00.00 - 13.05 - 13.07 - UR13.2V
          06 - 00.00 - 13.05 - 13.07 - UR13.2V
          07 - 00.00 - 13.05 - 13.08 - UR13.2V
          08 - 00.00 - 13.05 - 13.08 - UR13.2V
          09 - 00.00 - 00.00 - 00.00 - GND
          10 - 00.00 - 00.00 - 00.00 - GND
          11 - 00.00 - 00.00 - 00.00 - GND
          12 - 00.00 - 00.00 - 00.00 - GND
          13 - 00.00 - 03.29 - 03.29 - AC_DET
          14 - 00.00 - 02.84 - 02.84 - PS_ON
          15 - 05.03 - 05.02 - 05.03 - BU5V
          16 - 00.00 - 03.28 - 03.29 - PNL_POW
          17 - 00.00 - 00.00 - 00.00 - PWM1
          18 - 00.00 - 03.28 - 01.45 - NC
          19 - 00.00 - 00.57 - 00.00 - DIMMER
          20 - 00.00 - 03.28 - 01.45 - NC
          21 - 00.00 - 00.86 - 01.45 - OFL
          22 - 00.00 - 00.00 - 00.00 - ERROR
          23 - 00.00 - 00.00 - 00.00 - PWM2
          24 - 00.00 - 03.26 - 00.00 - STB
            OK, so the STB (BL-ON) drops out, and the PWM/Dimming controls are not present otherwise you would have seen the backlights come on for seconds before the STB drops out.
            BTW, once it is in last state as shown, if you activate the power switch again, does the PS-ON drops back to 0V?
            • StodgyWaif
              • Apr 2014
              • 40
              Yes PS-ON does go back to 0V after about 15 seconds after pressing the power button to turn off the TV.
              I rechecked 14, 17, 23 and 24 and the results were the same.
                So at least the main board is not completed locked since the PS-ON is still responding. I I will have to study the code and the service manual more in details to find out what is going on since the communication error does not seem the match the missing command signals.
                • StodgyWaif
                  • Apr 2014
                  • 40
                  Did you have a chance to look into this? I think in the manual that it states if there is no error lights then you should replace power supply then main board then LCD Control Unit. Page 6-4 of the manual I have.
                  • scubacamper
                    Sharp Aquos LC-70C6400U Half Screen Dark
                    by scubacamper
                    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                    05-03-2025, 12:19 PM
                  • sefoster
                    Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                    by sefoster
                    I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                    11-20-2022, 09:29 AM
                  • jonah1024
                    Sharp Aquos LC-40UG7252E LCD TV burn in?
                    by jonah1024
                    Hello!
                    I'm a few days old into this TV screens repair universe so please bear with me.
                    Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                    - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                    - I did a factory reset as well...
                    07-16-2024, 04:23 AM
                  • npielawski
                    MacBook Pro late 2016 (820-00239) with multiple failure modes.
                    by npielawski
                    I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                    I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                    10-15-2025, 01:53 AM
                  • klassic
                    Sharp Aquos LC-60LE635E three blinks
                    by klassic
                    Hi community,
                    I will describe my problem with a TV in those short following terms to be the most precise :
                    What i have :
                    power board DPS-162KP-1
                    main logic board QPWBXF733WJN2
                    symptoms :
                    white led light logo at startup,
                    after 2 minutes, blinking 3 times a row, repeating
                    no backlight (and apparently no picture, checked panel with flashlight)
                    no startup sound
                    powerboard investigations :
                    1-2 PNL : 0v
                    3-4 GND
                    5-6-7-8 UR : 13.15v
                    9-10-11-12...
                    10-24-2023, 01:39 PM
