Old Vizio E470VA, new problem
  • EMD_Driver
    • Aug 2017
    • 13
    I did a job for someone and she gave me a Vizio E470VA. She said lightning had struck and the TV no longer worked. Before throwing it away, I decided to test it and see what I could find.
    When the set is plugged in, the word Vizio below the screen lights up. It will then go off again. I can turn the set on with the remote, but I can see the entire screen flashing. It will go light and immediately dark. The flashing is very rhythmic and alternates about every second. I did an extensive search and could find no similar conditions. Also, while the screen is flashing, the Vizio logo below the screen does a very similar type of alternating between light and dim.
    I pulled the PSU and tested it today. I got proper voltage on each of the pins, but they fluctuated a bit. I also noticed a faint clicking around the lower corner of the board. That clicking has the exact same rhythm as the flashing I described before. I'm attaching two pics of the board, in the hopes that someone might be able to help me figure out where the clicking is coming from and whether I should replace the entire board. If I can replace a component, I would rather do that.
    Thanks!
    Gary
    Edit: I also uploaded a pic of the sticker on the board. The center pic is of the corner of the board where the faint clicking is coming from.
    Re: Old Vizio E470VA, new problem
    https://www.badcaps.net/forum/attach...2&d=1503435331
    We need to know what the DCV for all those pins of the two white connectors on the left side of the board. Make sure to put down the pin name first and follow by the Voltage reading for each pin, take the two sets of readings: one set when the TV is plugged in another set when the power switch is activated.
    • EMD_Driver
      • Aug 2017
      • 13
      I'll be happy to get those measurements for you tomorrow.
      One question..
      Would I get the voltages you need with the PSU out of the set and the PSON jumpered to one of the 5v terminals, or should the readings be taken with everything hooked up?
      Gary
      • williej
        • May 2005
        • 10
        Test it out of the set,5vsb to pson and read the voltage.
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          you need everything hooked up as normal. we need to see if you have command signals.
          WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
          • EMD_Driver
            • Aug 2017
            • 13
            I took the measurements both ways. With the PSU installed and on the bench, with the PS_ON jumpered. For the purpose of this post, I flipped the image and cropped it to highlight the connectors.
            The upper connector is labeled: CN903
            I will list the pins and the voltages obtained beside each one, while the board is installed and the power on.
            24v - 24.32-24.34v fluctuating.
            24v - 24.32v
            24v - 24.32v
            24v - 24.32v
            24v - 24.32v
            Gnd
            Gnd
            Gnd
            Gnd
            Gnd
            ENAELE - Unused
            On/Off - 0.11v
            Din - 3.37v
            The lower connector is labeled CN905.
            Same as above.. Board installed, power on.
            On/Off - 0v
            Dim - 0v
            12v - 11.89v
            12v - 11.89v
            Gnd
            Gnd
            Gnd
            24v - 24.32v
            24v - 24.33v
            PS_ON - 4.75v
            5v - 5.2v
            5v - 5.2v
            With the board on the bench, I got the following voltages:
            Connector CN903
            24v - 23.02-24.03v
            24v - 23.61-24.03v
            24v - 23.51-24.06v
            24v - 23.8-24.02v
            24v - 23.4 - 24.03v
            Gnd
            Gnd
            Gnd
            Gnd
            Gnd
            ENAELE - Unused
            On/Off - 0v
            Dim - 0v
            Connector CN905:
            On/off - 0v
            Dim - 0v
            12v - 12.02-12.04v
            12v - 12.02-12.08v
            Gnd
            Gnd
            Gnd
            24v - 23.8-24.09v
            24v - 23.4-24.02v
            PS_ON - 0v
            5v - 5.2v
            5v - 5.2v
            With the board on the bench, the fluctuating voltages corresponded to the clicking heard on the board. Could this be due to the lack of a load? If these voltages all look good, should I suspect the inverter, or the main board next?
            Thanks for the help!
            Gary
            • EMD_Driver
              • Aug 2017
              • 13
              I made a little 5 second video of what the TV is doing when powered on. Perhaps this will explain it a bit better than I could.
              Gary
                On/Off - 0.11v
                Din - 3.37v
                Those two above signals are from the main board, they are fed into one connector and out to another connector to go the Inverter board.
                Right now you do not have ON/OFF (BL-ON) signal from the main board to turn on the backlights circuit. You should verify that DIM signal again because you do have 3.37V on the input connector but not at the output connector that goes to the inverter board. You have problem on the main board some where, you can start by checking the Voltages of the Regulator ICs first.
                • maxvalutech
                  • 804
                  • australia
                  I have a couple of sets not same but similar make and note that at turn on the backlights come on bright then dim right down until picture time. Perhaps your set caught in this early bright/dim loop.
                  • EMD_Driver
                    • Aug 2017
                    • 13
                    Originally posted by budm
                    On/Off - 0.11v
                    Din - 3.37v
                    Thanks for the tip! I'll get those ICs checked and report back!
                    Gary
                    • EMD_Driver
                      • Aug 2017
                      • 13
                      I finally got to test the voltages on the ICs and here's what I got.. I checked each terminal twice, to be sure. I also attached two pictures of the ICs in question. I only found four on the board.
                      U103
                      M271
                      G9084
                      3.80
                      5.04
                      9.57
                      U608
                      17089
                      06 11
                      11.87
                      0.7
                      9.02
                      U704
                      M272
                      1117-18
                      0.8
                      1.794
                      3.301
                      U706M-153
                      1117-33
                      0.8
                      3.3
                      5.14
                      Hopefully, one of you guys will be able to decode all this and help me out.
                      Thanks for looking!
                      Gary
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Readings on U704 and U706M look fine. Unsure on the other two, i'm too sleepy and inebriated to look them up, wait for assistance from other members
                        A working TV? How boring!
                        • EMD_Driver
                          • Aug 2017
                          • 13
                          Guess I didn't hit enter hard enough..
                          U706M-153
                          1117-33
                          0.8
                          3.3
                          5.14
                          Should read:
                          U706
                          M-153
                          1117-33
                          0.8
                          3.3
                          5.14
                          • attainteddragon
                            • Apr 2013
                            • 764
                            • australia
                            i don't know what u608 is, but all of the other ldo's are good.
                            • EMD_Driver
                              • Aug 2017
                              • 13
                              Sorry about that..
                              U608 is a 17809
                              • attainteddragon
                                • Apr 2013
                                • 764
                                • australia
                                found the data sheet, and the output is good.
                                • EMD_Driver
                                  • Aug 2017
                                  • 13
                                  So if all four mainboard ICs are showing good, where should I look next? What would cause the On/Off of CN903 to read 0.11v?
                                  Thanks,
                                  Gary
                                  • attainteddragon
                                    • Apr 2013
                                    • 764
                                    • australia
                                    it could be a bad cap, bad solder joint under the bga processor, or potentially any other surface mounted device.
                                    you know for sure that you have a main board issue, so you can replace it, or you could trace back from the bl/on signal pin and try to find what may of failed. main boards are not easy.
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • H34TO
                                      ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                      by H34TO
                                      Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                      06-17-2025, 07:17 AM
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • slimmy182
                                      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                      by slimmy182
                                      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                      Looking on google I found this:...
                                      01-14-2023, 11:55 AM
