There is no firmware update on Samsung;s site for this tv. Any one know where to get one?
Samsung pn43d450a2dxza firmware update
Re: Samsung pn43d450a2dxza firmware update
The BadCaps forum saves the day again
I just fixed one by replacing the IGBT's on the X-sus board and i was looking for the firmware update
-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.Comment
I downloaded the update mentioned and the TV does not recognize it. I downloaded the file form the link above and unzipped it to USB. On the USB I get 2 folders T-MST4DEUC and T-MSV4DEUC. When I stick the USB in the TV does not find an upgrade.
I also found an old You Tube video (https://www.youtube.com/watch?v=PnOtcjs3snU) that shows how to download a firmware upgrade from the Samsung site. But that does not work either since the Samsung site has changed and the firmware upgrade is no longer available. Is the firmware upgrade no longer recommended since it was taken down. I have heard of TVs not working after firmware upgrades.Comment
They take them off their sites, not sure why, I think it's because they would rather have you buy another tv from them than give you the option to fix it with a simple firmware load. Could try contacting them, tell them you need the firmware, has worked for some.Comment
I tried the Samsung tech support but they say there is no update for this TV. Maybe there was an issue with the update and it got taken down. I will just hope the TV works a few more years then I will get another one when the boards fail again.Comment
Check the firmware version presently installed on your TV. Latest version: 1006.6
Here is Samsung Canada DL link for your TV:
https://www.samsung.com/ca/support/m...XZC/#downloadsComment
by Robby-GrHi all,
I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos -
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by GeckoGreenHi,
I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
Will you please help me get the [2D63]LOGIC.bin file for my TV?05-17-2025, 02:47 PM -
by rumpumpel1Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?10-24-2024, 08:59 AM
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... - Loading...
