Hisense f42k20e turns on, screen goes dark
  • dick_barton
    replied
    Re: Hisense f42k20e turns on, screen goes dark
    If you place your meter probes between the two legs of C810, what DC voltage do you have in standby and out of standby?
  • x_orange90_x
    replied
    I just realized the first picture of the back of the set is incorrect. Please ignore that one.
  • x_orange90_x
    replied
    Originally posted by budm
    Do you get the same reading if the connector to the LEDs is not connected?
    It sounds like you have open circuit in the LED string.
    Yes, I get the same readings without them even plugged in.
    In the picture attached, the coil with the black bands on it makes a low pitch buzzing sounds when the tv is in standby, and stops when it's switched on. The large yellow block with the sticker on it makes a strange sound when the leds light up, then stops when they go off (even with them disconnected). The sounds it makes is a little reminiscent of a hard laptop drive if that makes any sense.
  • dick_barton
    replied
    Any pictures of your circuit boards would be useful.
    replied
  • x_orange90_x
    started a topic Hisense f42k20e turns on, screen goes dark
    I have a hisense f42k20e that powers on and the power light flashes between red and blue about 6-7x, then a couple more times and remains blue. The panel lights up bright white then fades to black. I can see images on the screen after it fades. When it lights up there is a quick buzzing noise that sounds like it's coming from the power supply, and when the screen goes black the buzzing stops.
    I took the following voltages on the LED strips:
    1+ -- spike to 280v, drops to 133v
    2+ -- spike to 130v, drops to 0v
    I'm not sure what these voltages are really telling me. They don't match what I have seen in the past with other tvs.
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Rav_tangle
    MacBook Pro 2011 turns on with keyboard light , screen dead
    by Rav_tangle
    Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
    I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
    Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
    is this...
    05-31-2024, 04:09 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • krige
    asus g750js ms1130c (203) turns on nothing on the screen
    by krige
    hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
    03-22-2024, 04:59 AM
  • Runlinc
    Hisense 55E76GQTUK screen removal?
    by Runlinc
    Hi all, I need to change the backlights in a Hisense 55E76GQTUK. The screen is glued to the chassis, what is the easiest way of delaminating the screen from the chassis please?
    also what double sided tape would you recommend to glue it back in? ….. or is that a question to ask once the screen is out in one piece?
    Many thanks for any ideas you have.
    04-09-2024, 10:02 AM
