Lg 32ln5300 32
  • muskin
    • Nov 2011
    • 64
    Lg 32ln5300 32
    Hi I just picked up a LG 32LN5300 32". Today it started having a white 2" image on the screen. Is this the back light strip, just wondering.
    When no image is on the screen the white inprint is very noticable, but while a picture is on the screen it is less noticeable.
    thanks
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Lg 32ln5300 32
    some pics would be a good start.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • muskin
      • Nov 2011
      • 64
      Re: Lg 32ln5300 32
      not really good pictures, but you can see the white area on the screen. The area below the no signal bar.
      • diif
        • Feb 2014
        • 6978
        • England
        Re: Lg 32ln5300 32
        I wonder of one of the reflectors that cover the LEDs has become lose so the light isn't being reflected in the same way the others are.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Re: Lg 32ln5300 32
          Looks like lens fell off backlight led
          • muskin
            • Nov 2011
            • 64
            Re: Lg 32ln5300 32
            After thinking about it, you guys are probably right. Are they a way to get the lens back on ?
            • diif
              • Feb 2014
              • 6978
              • England
              Re: Lg 32ln5300 32
              I use super glue gell. You will have to take the screen apart though.
              • muskin
                • Nov 2011
                • 64
                Re: Lg 32ln5300 32
                That's the hard part, hoping to not mess up the screen. Super glue last pretty good. I have some loctite super glue.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Re: Lg 32ln5300 32
                  Make sure they are centered or will have crescent shaped spots instead
                  • CapLeaker
                    Leaking Member
                    • 7972
                    Re: Lg 32ln5300 32
                    IF the lens fell off the LED, than this thing should rattle.
                    • R_J
                      • 9514
                      Re: Lg 32ln5300 32
                      Or a couple other leds have shorted causing that one to be brighter.
                      • muskin
                        • Nov 2011
                        • 64
                        Re: Lg 32ln5300 32
                        picture is pretty good. except for that bright spot. Hopefully its one lens off.
                        Thanks Guys.
                        I have 3 more 12 hour days to work then I'll pop it open.
                        • muskin
                          • Nov 2011
                          • 64
                          Re: Lg 32ln5300 32
                          Okay I just opened the tv up and this is what I found. What's the best glue to attach the lens back with. The strips needs to be glued better too. any ideas.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Re: Lg 32ln5300 32
                            I use 3m double sided tape to stick the strips to the metal and super glue Power Flex Gel for the lenses.
                            • muskin
                              • Nov 2011
                              • 64
                              Re: Lg 32ln5300 32
                              where can I locate some 3m double sided tape.. big box stores carry them or do you have to order it from an electronic store.
                              • muskin
                                • Nov 2011
                                • 64
                                Re: Lg 32ln5300 32
                                something like this https://www.lowes.com/pd/LOCTITE-4-G...hesive/4330052
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  Re: Lg 32ln5300 32
                                  That's the stuff.
                                  I've got sheets of 200MP adhesive I've cut into strips. It's stronger than regular double sided tape. There's plenty of fake stuff about but I got mine from ebay.
                                  • muskin
                                    • Nov 2011
                                    • 64
                                    Re: Lg 32ln5300 32
                                    thanks diif, I just got through. The lens turned a yellow color with the glue under it.. I hope this will be ok.. gonna let it dry for a long time before I stand it back up.
                                    Hoping it works.
                                    • muskin
                                      • Nov 2011
                                      • 64
                                      Re: Lg 32ln5300 32
                                      well after letting set most of the day, I fired it up. Looks better but has a little darker are where the lens is. I can watch it like this for now, but I know sooner or later I will be wanting to fix it right. Where can I get some of these small lenses.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        Re: Lg 32ln5300 32
                                        Shopjimmy has led and lens kit
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • dicky96
                                          HP Elitebook Screen blank - backlights but no image
                                          by dicky96
                                          Hi guys
                                          I'm trying to fix this laptop screen
                                          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                          OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                          04-28-2021, 07:30 AM
                                        • x_orange90_x
                                          Samsung LN37A550P3FXZA White screen with image
                                          by x_orange90_x
                                          So I've had this TV for a while now and I'm just getting around to trying to fix it. It has a bright white image right off the bat (as of now). Colors are normal and the image looks good, however the entire screen is washed out with white and subtle ghosting. I found a thread somewhere which someone claimed it was the long strips connecting the TCON to the LCD which were bowing and shorting out on the metal LCD frame. I took mine apart and found exactly that. They were bowed out, so I put electrical tape across them along with some padded spacers. Previously, before doing this, the image was polarized...
                                          03-26-2020, 02:06 PM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
