'04 CRT trouble
  • electroguy75
    • Dec 2008
    • 21
    '04 CRT trouble
    i would suspect the infrared detector circuit in the tv. try disabling it c if it stops turning on off. cheers and good luck friend
  • weirdlookinguy
    • Sep 2007
    • 1638
    '04 CRT trouble
    Found this by the side of the road. It works, but often starts turning itself off, then on, then off, then on, then off, then on.... etc. etc. Also remote doesn't work. Any ideas?
    Chassis has crapcaps.
    • stevo1210
      • Oct 2006
      • 4156
      Re: '04 CRT trouble
      It doesn't make clicking sounds like a faulty flyback does it?
      Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
      • weirdlookinguy
        • Sep 2007
        • 1638
        Re: '04 CRT trouble
        Nope, definitely not the flyback.
        I actually left it outside dissasembled for two days and was planning to throw it away tonight, but when I got home I found it playing nicely in the kitchen! Turns out my dad went through and dusted the chassis then put it back together and it's been on for about 4 hours without turning off. He thinks maybe some setting in the microprocessor was corrupted and letting it sit unplugged for a while cleared the memory, just like our old Sanyo would do sometimes (it would start flipping channels on its own). That could be possible, or maybe marginal crapcaps, or I was thinking maybe a dirty relay. Whatever the case, it's a nice TV and we're keeping it. If it starts acting up again I will clean the relay and start testing caps.
        EDIT: Also, the remote worked the whole time. I noticed it was only the volume buttons that wouldn't work, and this was before it fixed itself, but I forgot to come back here and edit my post. My dad took the remote apart and cleaned that too and now all the buttons work.
        • Krankshaft
          • Jan 2007
          • 2328
          Re: '04 CRT trouble
          Check the board carefully with a magnifier it probably has a cracked solder joint somewhere.
          I have saved plenty of TVs from the dumpster because of this.
          On I recently saved a Sharp and a nice 27" Panasonic they were on through hole parts one on the Sharp was on a reset IC (in a small transistor TO package) for the microcontroller and the other was on an NPN transistor on the Panasonic.
          Giving the TV the whack test or poking the board with a wood dowel will confirm when it decides to act up.
          Have fun I know I would be .
          • weirdlookinguy
            • Sep 2007
            • 1638
            Re: '04 CRT trouble
            Well it started up again today.
            Not surprising in the least.
            I will definitely smack it when it starts shutting off to see if it's a solder joint or not. Also do you guys think a screwed up relay is a possibility here? Is there any way to clean them?
            • weirdlookinguy
              • Sep 2007
              • 1638
              Re: '04 CRT trouble
              Oops, I meant started ACTING up again today. Editing time limit has passed.
              • larrymoencurly
                • Oct 2004
                • 960
                Re: '04 CRT trouble
                No Sams Photofact for that model.
                Resolder a bunch of joints? That recently did the trick for my old Sanyo, which had intermittently showed snow when the RF input was used, and it hadn't responded to inertial repair attempts, i.e., whacking the cabinet, even though that always made the picture flicker. But even that flicker disappeared after I resoldered, and now I'll be able to enjoy analog TV channels for many more years, right?
                Actually the TV had been bad for several months, but I didn't get to it until the vertical output started to act up recently and made the picture shake badly during the first 30 minutes and remain stretched and with bad interlace. Replacing three Jamicon capacitors in the vertical circuit that measured 3-50 times the normal ESR made the TV normal again. Oddly none of the Jamicon capacitors in the horizontal circuit showed high ESR.
                • timmerfrans
                  Having trouble disabling RAM for Thinkpad E14 Gen 3 AMD!
                  by timmerfrans
                  Specs:
                  E14 Gen 3 with AMD
                  20Y7-CTO1WW
                  Onboard RAM defect
                  Hey all, I am trying to disable the onboard RAM on this 8 core AMD Thinkpad. I've hooked up the CH341A at 3.3V (not 1.8V because yolo). The chip I'm reading off of is a Winbond 74m25jweiq 32MB chip. I can't select the 74xx chip in any of the CH34 programmers I've tried so I just select a different Winbond chip that is 32MB. I wrote the bios to a file and verified it, modded it with BIOS memory SPD removal tool and flashed it back onto the board. When I verify it now, it errors and the laptop won't
                  05-19-2024, 04:08 PM
                • Sparklingx
                  HP 450 g1 keeps turning on even tho shutdown/sleep
                  by Sparklingx
                  HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                  09-23-2024, 12:34 AM
                • khelane
                  Satellite PRO A50-A Not turning on after turning off Windows
                  by khelane
                  Hello
                  A device with specifications
                  Toshiba Satellite PRO A50-A is here to replace the hard drive.
                  The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                  The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                  04-20-2023, 06:28 AM
                • Rabit
                  VX3276-2K-mhd-2 Random Turning off
                  by Rabit
                  Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
                  When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
                  This can be signs of bad capacitors causing overheating PSU ?
                  06-17-2024, 09:30 AM
                • shakib200
                  Dell latitude E7240 not turning on if adapter plugged in
                  by shakib200
                  Laptop turns on only on battery but if I plugged the adapter with battery, it is not turning on. After turning on the laptop using only battery (no adapter plug in), then plugging the adapter everything works fine also charging ok. Anyone have any clue what’s wrong?...
                  03-31-2024, 12:55 PM
