samsung un40eh5000f
  • stevemaho
    • Jan 2015
    • 23
    • usa
    samsung un40eh5000f
    Hi guys hope i can get some help here with this samsung tv
    I wasnt getting any voltage output and no standby light so replaced the power supply board and now i get standbt voltage on the pins and wn remove the connector from mainboard to power supply back light comes on but wn i plug back connector the standby voltage goes to 0 backlight goes off and black screen wn i test the main board side no voltage coming in
    What do you think can be the prob?
  • Hamie
    • Apr 2014
    • 1383
    Re: samsung un40eh5000f
    I'd guess the mainboard has a short and pulls down the standby voltage.
    Plug the tv in for a few minutes, then unplug. touch a few of the components on the main board. See if anything is too hot to touch.
    • stevemaho
      • Jan 2015
      • 23
      • usa
      Ok did that but nothing gets got but i trace the connections and it goes to a 17-33z voltage regulato0r so gonna remove see if voltage reaches to that point
      • stevemaho
        • Jan 2015
        • 23
        • usa
        Ok just replaces the mainboard now the board does not draw the 5.3v away so thats good and the mainboard gets power tested a couple points but still no standby light or anything
        Any help will be appreciated
        • michael first
          • Feb 2013
          • 7
          • italy
          Hi,I'd check the connector on the power supply and the flat cable to the main board.
          Quite often you'll find the body of the connector yellowish, so the cure is to replace both
          of them.
          • stevemaho
            • Jan 2015
            • 23
            • usa
            Cables are fine mainboard getting power now than with old main board tested on main board and i get the 5v stanby but i guess might be tcon board now need to be replaces
            • diif
              • Feb 2014
              • 6978
              • England
              Measure voltage both sides of the fuse on the tcon.
              • stevemaho
                • Jan 2015
                • 23
                • usa
                ok no voltahge o the fuse on tcon
                • CapLeaker
                  Leaking Member
                  • 8116
                  Post a high resolution pic of your main board.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    You measured both sides ? Is there continuity across the fuse ?
                    • stevemaho
                      • Jan 2015
                      • 23
                      • usa
                      Fuse is good have continuity but seems like no voltage coming across from mainboard to tcon but this is a new board i just bought off ebay and was told it was tested and working fine
                      Thanks in advance guys
                        Regardless to the T-CON board, do you get the backlights to come on?
                        It sounds like defective new main board to me if ALL the power supplies Voltages are OK.
                        "Ok just replaces the mainboard now the board does not draw the 5.3v away so that's good and the mainboard gets power tested a couple points but still no standby light or anything"
                        The key point is that you are not even getting the Standby light with the replacement main board.
                        • stevemaho
                          • Jan 2015
                          • 23
                          • usa
                          BUT in this case the STAND BY light comes on only when tcon gets power correct?
                          So the replacement board has an issue most likely cause the tcon not getting and voltage from mainboard not even by the fuse?
                          And what are the chances that the ribbon cable from mainboard to tcon is bad?
                          Anything else to chk or just return board to seller?
                            Standby light is for telling you the TV is not on and it is in standby mode. You will have to look up the user manual for your model to see if that light in front is for power on indicator or standby indicator.
                            Also you are not telling us if you ALL the Voltages from the power supply and the backlights or not with your new board when you turn on the TV with the remote or with the switch on the TV..
                            http://downloadcenter.samsung.com/co...0404145915256/[UE4000-5000-ZA]BN68-04499A-02-ENG-1016.pdf
                            • stevemaho
                              • Jan 2015
                              • 23
                              • usa
                              Ok wn i press power button on remote no lights come on in front and no power drop on the standby pin 5v and no power on fuse on tcon board either.
                              This model has no power button the side its a touch model and all the pins on smp are correct the 13v and the 5v all are correct on the pins and wn i remove cable from mainboard to smp backlight comes on fine
                                Sounds like your supposedly good replacement board is no good and we already know that the power supply board is good.
                                • CapLeaker
                                  Leaking Member
                                  • 8116
                                  Sounds like your main board is bad. You can try to reflow the main IC on the main board. If that is a replacement board, send it back. It's bad.
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    What voltages do you have on Power ON/OFF Pin 14 of CNM803 and also on BLU On/Off Pin 6 of CNM803 when you in standby and when you try to come out of standby.
                                    • stevemaho
                                      • Jan 2015
                                      • 23
                                      • usa
                                      Which ic u referring to to relow?
                                      And on pin 14 5.3v and pin 6 12.52v when i hit power button on remote voltage doesn't change
                                      Thanks guys
                                      • thoma
                                        • Sep 2012
                                        • 268
                                        WAIT UNTIL GET MANUAL APPEARS
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • x_orange90_x
                                          Samsung UN55KU6300F no standby voltage
                                          by x_orange90_x
                                          I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                                          Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                                          05-21-2025, 09:59 PM
                                          09-07-2024, 05:50 AM
                                        • Sportline
                                          Samsung LE32S81B - missing standby voltage
                                          by Sportline
                                          Good day, instead of Q0165R I mistakenly put 24C256 (don't ask me how) and made a short circuit. After I put Q0165R I don't have stand by voltage again. There is no voltage on the cold side. I found the schematic.
                                          I checked a few things but didn't find anything. When I checked the DB802 diode, it showed a short circuit, but when I unsoldered one leg, it looked fine, and I still have a short circuit on its contacts. On the other side of the board, I have DZB801 also shorted, but it is SOT23, so I didn't remove it, do you think it could be connected to it? Could there be some protection...
                                          03-10-2023, 06:38 AM
                                        • Bad_IC
                                          Philips TV 37pfl5604h/12 no standby voltage
                                          by Bad_IC
                                          I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                                          These are the voltages in some pins of IC fsq510:
                                          Vcc=18v
                                          D=320v
                                          Vstr=154v
                                          Unfortunately, I couldn't find the schematic
                                          What else could I check?
                                          Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                                          Thank you​...
                                          11-08-2024, 01:07 PM
