Sony KDL-32L4000 bad t-con or panel?
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    I've got a KDL-32L4000 that displays this weird image (see photo). Sorry about the picture quality, was holding the TV with one hand and taking a photo with my smartphone in the other.
    About the third of the screen is sharp and static, the rest is moving like it's being refreshed constantly one over the other sort of like a ghost.
    Is there a way to find the culprit without actually replacing the t-con as I'd have to order one.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony KDL-32L4000 bad t-con or panel?
    Looks like maybe panel problem. May try flexing panel and see if any change
    • Half-Saint
      • Jan 2010
      • 213
      • Slovenia
      To flex it properly, I'd have to remove it from the bezel. Tried flexing it while still inside the TV frame with no results.
      I'll see, if I can make a video of the problem and post it on YT.
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        +1 for panel.
        you can confirm by opening the back, disconnecting one side of the t-con that connects to the panel. powering the set up and checking picture, then repeat for the opposing side.
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • Half-Saint
          • Jan 2010
          • 213
          • Slovenia
          If I remove the flat cable, there's no picture, only the backlight is on.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            the ribbon that goes to the panel? not the lvds that goes from the main board to the t-con.
            is there 1 or 2 cables?
            • Half-Saint
              • Jan 2010
              • 213
              • Slovenia
              There's just one flat cable that goes from the t-con to the LCD so I can't really do what you suggested.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                well, that ruined that idea.
                i'm still looking at panel. if you want to pull it down to the panel and apply pressure to the tab bonds to see if it is causing the fault, then it is your call. nothing to lose in my opinion though.
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  Sorry to say but its the panel
                  • Half-Saint
                    • Jan 2010
                    • 213
                    • Slovenia
                    Ah well, it's not very likely that I'll be finding a compatible panel any time soon. I'll just use it for parts. Cheers guys.
                      • 12146
                      • U.S.
                      Hard to tell by the pic., you could try a firmware update, might work, sometimes the firmware gets buggered up. Tcon boards are readily available and usually pretty reasonable in price.
                      • rimwall
                        Sony KD-65x8500b - bad Tcon or panel?
                        by rimwall
                        Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                        a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                        b) the Tcon board is malfunctioning,...
                        10-24-2023, 07:58 PM
                      • AK_777
                        Sony KD-65A1 Repair – 4 Red Blinks Error
                        by AK_777
                        Hi everyone!
                        I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                        Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                        02-20-2025, 04:15 PM
                      • x_orange90_x
                        TCL 50S535 bad tcon or panel issue?
                        by x_orange90_x
                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                        03-29-2025, 11:02 PM
                      • swrb898
                        Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                        by swrb898
                        What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                        Problem:
                        Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                        My troubleshooting got me this far:
                        With the left-hand TCON to bottom-board ribbon cable...
                        12-28-2021, 08:12 PM
                      • advant
                        by advant
                        02-03-2020, 12:25 AM
