Sony KDL-32L4000 bad t-con or panel?
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    I've got a KDL-32L4000 that displays this weird image (see photo). Sorry about the picture quality, was holding the TV with one hand and taking a photo with my smartphone in the other.
    About the third of the screen is sharp and static, the rest is moving like it's being refreshed constantly one over the other sort of like a ghost.
    Is there a way to find the culprit without actually replacing the t-con as I'd have to order one.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony KDL-32L4000 bad t-con or panel?
    Looks like maybe panel problem. May try flexing panel and see if any change
    • Half-Saint
      • Jan 2010
      • 213
      • Slovenia
      To flex it properly, I'd have to remove it from the bezel. Tried flexing it while still inside the TV frame with no results.
      I'll see, if I can make a video of the problem and post it on YT.
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        +1 for panel.
        you can confirm by opening the back, disconnecting one side of the t-con that connects to the panel. powering the set up and checking picture, then repeat for the opposing side.
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • Half-Saint
          • Jan 2010
          • 213
          • Slovenia
          If I remove the flat cable, there's no picture, only the backlight is on.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            the ribbon that goes to the panel? not the lvds that goes from the main board to the t-con.
            is there 1 or 2 cables?
            • Half-Saint
              • Jan 2010
              • 213
              • Slovenia
              There's just one flat cable that goes from the t-con to the LCD so I can't really do what you suggested.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                well, that ruined that idea.
                i'm still looking at panel. if you want to pull it down to the panel and apply pressure to the tab bonds to see if it is causing the fault, then it is your call. nothing to lose in my opinion though.
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  Sorry to say but its the panel
                  • Half-Saint
                    • Jan 2010
                    • 213
                    • Slovenia
                    Ah well, it's not very likely that I'll be finding a compatible panel any time soon. I'll just use it for parts. Cheers guys.
                    • nomoresonys
                      • 12331
                      • U.S.
                      Hard to tell by the pic., you could try a firmware update, might work, sometimes the firmware gets buggered up. Tcon boards are readily available and usually pretty reasonable in price.
                      • iglitare
                        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                        by iglitare
                        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                        Backlight seems to work, Sound (Setup menu after reset) works.
                        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                        With my small knowledge i would think at least the cables are good.
                        Can this happen because of a bad tcon board?
                        Or is it always a bad/shorted...
                        09-04-2025, 07:13 AM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • rimwall
                        Sony KD-65x7500D - double image - Tcon or Panel?
                        by rimwall
                        This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                        I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                        11-18-2025, 02:09 AM
                      • rimwall
                        Sony KD-65x8500b - bad Tcon or panel?
                        by rimwall
                        Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                        a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                        b) the Tcon board is malfunctioning,...
                        10-24-2023, 07:58 PM
                      • AK_777
                        Sony KD-65A1 Repair – 4 Red Blinks Error
                        by AK_777
                        Hi everyone!
                        I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                        Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                        02-20-2025, 04:15 PM
