Board capacitors
  • Samantha143
    • Apr 2017
    • 21
    • Usa
    Board capacitors
    Hey guys this might be a stupid question but I want to know if it's even possible before attempting... I have two exact tv boards they both are not working. One has two bad popped capacitors and I don't know what's wrong with the other one. My question is can I cut at the curve ( see pictures) the two capacitors that are good on one board and cut out the ones that are bad leaving the two legs and Solder it to make them "like new" capacitors. I know it might sound confusing it's just if I remove the soldered legs won't be long enough so I am trying I use the good capacitors into the old capacitor legs ... I am attaching a picture
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: Board capacitors
    The term is "solder".
    • diif
      • Feb 2014
      • 6978
      • England
      Surely if you are removing the caps from one identical board to swap into another in the identical position the 90 degree bend in the cap legs will fit the board perfectly so they don't need cutting ?
      • petehall347
        • Jan 2015
        • 4439
        • United Kingdom
        dont cut anything .. just put new ones in there .unless you are in a rush and have a proper cap tester .
        • Samantha143
          • Apr 2017
          • 21
          • Usa
          Thank you cliff.. not sure why my auto correct was replacing it with that word. ��*♀️
          • Samantha143
            • Apr 2017
            • 21
            • Usa
            So you wouldn't recommend removing them from the old board even if they are the same ??
            • cliff_hootarski
              • Jul 2006
              • 411
              No problem, Lord only knows how many times "auto-correct" has changed my wording.
              Sure you could cut the leads, but if they are the same exact boards and the caps are the exact same value, why not just de-solder both pair and solder in the "good" caps in place of the "popped" ones?
              • neilc6
                • Nov 2015
                • 1550
                If you cut the caps at the bend and try to resolder, the lead sticking up might drop down through the hole once you heat it up making it even more difficult. Easier to remove the cap by pulling up on the body while heating the bottom pad. Be careful not to splash solder into your eyes. Though swapping caps from another board may seem like a quick test, the more you remove and replace parts, the more likely you are to cause damage. Better to just order and replace with new caps from Digikey.
                  by sam_sam_sam
                  After all of...
                  07-13-2024, 08:14 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • AlexForTheWin
                  Help Diagnosing ASRock Taichi X570 Motherboard
                  by AlexForTheWin
                  Hi all! I'm a newbie to to the forum and electronics repair in general.
                  I picked up a nonfunctional ASRock Taichi X570 motherboard that someone threw away. My main goal is it to repair and use it. But even if it's not possible, I'd like to learn about the process.
                  I'd very much appreciate some guidance.
                  Here are the steps I've taken to diagnose the board:
                  I first tried powering the board without a CPU or memory. The lights turned on. As you'd expect, the board wouldn't boot.
                  Hoping the board worked, I bought a compatible CPU on amazon. I wanted...
                  12-16-2022, 11:37 PM
