Hey guys this might be a stupid question but I want to know if it's even possible before attempting... I have two exact tv boards they both are not working. One has two bad popped capacitors and I don't know what's wrong with the other one. My question is can I cut at the curve ( see pictures) the two capacitors that are good on one board and cut out the ones that are bad leaving the two legs and Solder it to make them "like new" capacitors. I know it might sound confusing it's just if I remove the soldered legs won't be long enough so I am trying I use the good capacitors into the old capacitor legs ... I am attaching a picture
Board capacitors
Tags: None
Re: Board capacitors
dont cut anything .. just put new ones in there .unless you are in a rush and have a proper cap tester .Comment
Thank you cliff.. not sure why my auto correct was replacing it with that word. *♀️Comment
So you wouldn't recommend removing them from the old board even if they are the same ??Comment
No problem, Lord only knows how many times "auto-correct" has changed my wording.
Sure you could cut the leads, but if they are the same exact boards and the caps are the exact same value, why not just de-solder both pair and solder in the "good" caps in place of the "popped" ones?Comment
If you cut the caps at the bend and try to resolder, the lead sticking up might drop down through the hole once you heat it up making it even more difficult. Easier to remove the cap by pulling up on the body while heating the bottom pad. Be careful not to splash solder into your eyes. Though swapping caps from another board may seem like a quick test, the more you remove and replace parts, the more likely you are to cause damage. Better to just order and replace with new caps from Digikey.Last edited by neilc6; 07-09-2017, 06:32 PM.Comment
Assuming...7 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Hi all! I'm a newbie to to the forum and electronics repair in general.
I picked up a nonfunctional ASRock Taichi X570 motherboard that someone threw away. My main goal is it to repair and use it. But even if it's not possible, I'd like to learn about the process.
I'd very much appreciate some guidance.
Here are the steps I've taken to diagnose the board:
I first tried powering the board without a CPU or memory. The lights turned on. As you'd expect, the board wouldn't boot.
Hoping the board worked, I bought a compatible CPU on amazon. I wanted... - Loading...
