Samsung UE40C6000RWXXN clicking power board issue
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung UE40C6000RWXXN clicking power board issue
    There are 8 pins on ICM802
    Pin 1 = ??
    Pin 2 = ??
    etc
    Pin 8 = ??
    But be very careful not to slip with your meter probe when measuring the voltages.
      I do not see the PFC Voltage report, is it still at 388Vdc as the before the accident happen?
      BTW, this power supply board is know for bad solder joints, especially around the transformer legs that are soldered through the thru-hole rivets.
      • sepper
        • Jul 2017
        • 32
        • Belgium
        Pin 1 = ??
        Pin 2 = ??
        etc
        Pin 8 = ??
        GD1 5
        VCC 13
        GND 0
        GD2 5
        DT 2.2
        RT 2.5
        OC 0.7
        SS 2.2-5 switching
        • sepper
          • Jul 2017
          • 32
          • Belgium
          If I measure between CP803 - leg and RM814 I get 388V
            I would check the resistance of the resistor network for the protection circuit RM814~818, 825.
            • sepper
              • Jul 2017
              • 32
              • Belgium
              #26
              I only get 500k Ohm on my RM814 RM815 and RM817 should I get 1M instead?
              RM816 - 950k ohm
              RM818 - 17.8k ohm
              RM825 - 17.9k ohm
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                ICM801 appears to have a good working VCC. The data sheet says when VCC exceed 10.5V the device is enabled.
                SS switching is odd so as BudM says checking those resistors would be a good step.
                Does your power supply match the schematic diagram in this thread
                RM814 & RM815 = 910K
                RM816 & RM817 = 1M
                The resistors should read those values but sometimes when in circuit they do not read correctly so I normally unsolder them to check.
                • sepper
                  • Jul 2017
                  • 32
                  • Belgium
                  #28
                  RM816 & RM817 = 1M
                  My power supply is 220v ac or isnt that what you mean? Mmmm never soldered smd before. I give it a try tomorrow.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    I mean the voltage needed to operate the IC appears to be within spec.
                    Don't lose the resistors when you unsolder them so best do one at a time.
                    • sepper
                      • Jul 2017
                      • 32
                      • Belgium
                      #30
                      I unsoldered RM814 and it was 910k all the other values where ok too on circuit. So no need to unsolder them I guess?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #31
                        Can you check the voltage across the legs of capacitor CM806. If the voltage is not stable can you take it out and check the value is still 47uF
                        • sepper
                          • Jul 2017
                          • 32
                          • Belgium
                          #32
                          Can you check the voltage across the legs of capacitor CM806. If the voltage is still switching can you take it out and check the value is still 47uF
                          13v without switching
                          I measure a stable 5.8v over CM803 but on CM802 I measure 0.8v. Is this weird?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #33
                            According to section 7.3.1 once the voltage at SS increases beyond 1.2V the IC starts to generate gate-drive signal.
                            It looks as though the IC must be trying to start but failing for some reason and restarting.
                            I'm out of idea's at the moment but maybe someone else can offer further help.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              CM803 is connected to ICM802 (SS pin) = 5.8V
                              SS => 1.2V to drive the mosfets so that looks OK
                              CM802 connected to ICM802 (OC) = 0.8V
                              Should be <= 0.6V for soft start to recover.
                              Have you checked the two smaller fuses for continuity.
                              Other than that I'm still none the wiser at this point other than maybe try a replacement UC25600 which are not expensive.
                              • sepper
                                • Jul 2017
                                • 32
                                • Belgium
                                #35
                                FM801S is this a diode fuse? Because one side is 1.2k ohm other side is OL.
                                Other fuse is Ok.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  I've put red arrows showing the two fuses Post #34. They are small metal capped ceramic fuses. You need the set switched off and then measure using your meter set to ohms across each of them in turn.
                                    Hmm, I thought the simple test of the fuses were done per post #1 already and they were fine, right?
                                    "I don't know where to look now. I have a multi meter and tried to check some fuses and they look ok on the board. Any tip where to look now?"
                                    • sepper
                                      • Jul 2017
                                      • 32
                                      • Belgium
                                      #38
                                      Yes. The fuses are ok.
                                      FB801S 0.5 ohm
                                      FM801s 1.2k ohm in one direction and other direction open circuit... So it's acting like a diode as I already asked. It's not really saying something about that on the diagram or do I need to unsolder it.
                                        Fuses on that board should all show < 1 Ohms (depend on your probe leads resistance), if not then it is bad.
                                        • sepper
                                          • Jul 2017
                                          • 32
                                          • Belgium
                                          #40
                                          Ok, I think we have a winner... I unsoldered it. Gives OL. So its 100% broken.
                                          Can I just bridge it for a quick test or is this not done?
                                          • Asraf Atb
                                            by Asraf Atb
                                            01-27-2025, 05:02 PM
                                          • ohren
                                            by ohren
                                            09-08-2023, 05:24 PM
                                          • C152Heavy
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                          • Kjell
                                            Samsung Series 9 - BIOS issue
                                            by Kjell
                                            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                            08-01-2025, 09:15 AM
                                          • alltvrepairs
                                            Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
                                            by alltvrepairs
                                            I have confirmed that I have a mainboard problem.
                                            I have tracked no hardware issued on board so might be a software dump required.
                                            I have searched a bit but wasn't able to find anything for my screen:
                                            Here are some more details:
                                            Panel: cy-nn065hgev1h
                                            Main: BN94-14180M P08F
                                            Your help much appreciated!
                                            05-16-2025, 03:03 AM
