Samsung UE40C6000RWXXN clicking power board issue
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    #41
    Re: Samsung UE40C6000RWXXN clicking power board issue
    Fuses are for protection. Bridging it removes the protection and you could easily end up with parts blowing up giving you an even bigger problem than you have already.
    Best replace it with likewise fuse.
    If FM801S is blown then you need to recheck the mosfets Q803 & Q803 with your set powered off and using your meter set to diode mode --!>--
    to see if they have are short circuit. It would also be wise to check all the diodes around that part of the circuit. DM810, DM811, DM812,
    • sepper
      • Jul 2017
      • 32
      • Belgium
      #42
      Ok, I have to order one Hopefully it's here tomorrow but It's late so I guess it will be here on friday.
      Sorry for letting you guys search so deep in the diagram because of a stupid fuse mistake. I thought it was acting as a diode. Learned a lot already. I hope the issue will be fixed by the replacing the fuse. Keep you guys posted. And thanks a 1000x times!
        You need to check MOSFETs QM802, and QM803 for shorted circuit between Source pin and the Drain pin.
        • sepper
          • Jul 2017
          • 32
          • Belgium
          #44
          They are all shorted
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            #45
            If FM801S is blown then you need to recheck the mosfets Q803 & Q803 with your set powered off and using your meter set to diode mode --!>!--
            It would also be wise to check all the diodes around that part of the circuit. DM810, DM811, DM812, dual diodes DM804, DM806 as well as checking the resistors.
              All the resistance reading combination of all 3 pins show <1 Ohms?
              • sepper
                • Jul 2017
                • 32
                • Belgium
                #47
                Around 1-2 ohms on circuit
                  Well, remove them and test them off the board next.
                  • sepper
                    • Jul 2017
                    • 32
                    • Belgium
                    #49
                    Well, remove hem and test them off the board next.
                    1.5 ohm from gate to drain and 2.2 ohm from source to drain for QM803
                    0.9 ohm from gate to drain and 2.2 ohm from source to drain for QM802
                    • sepper
                      • Jul 2017
                      • 32
                      • Belgium
                      #50
                      I have new fuses. They are bigger then the original because otherwise I had to wait too long. But the value is the same 2A 250V. So I can make them fit.
                      Should I investigate something more before I put the power on again?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #51
                        Did you change the mosfets or is it just the fuse you have replaced ?
                        • sepper
                          • Jul 2017
                          • 32
                          • Belgium
                          #52
                          Just the fuse. Are the mosfets broken according to my measurements?
                            Time delayed fuse for the replacement?
                            Change the MOSFETs, the IC that drives the MOSFETs may be damaged also.
                            • sepper
                              • Jul 2017
                              • 32
                              • Belgium
                              #54
                              Arghhh.. I missed it completely because I wanted to order before the shop closed -.-. I got a slow blow...
                              I think I just order myself a new board found one on aliexpress for 25 dollar that's the same price I spend on the components already because I bought them x25
                              I'm just to noobish to fix this myself I guess. So I better spare you guys time But I would like to thank all of you for the incredible help and fast responses!
                                Time delayed = Slo-Blo
                                • sepper
                                  • Jul 2017
                                  • 32
                                  • Belgium
                                  #56
                                  Oh ^^
                                  Well , I soldered my fuse. And I thought let's just give a try Plenty of fuses in the house. But I plugged in and it blew my fuse holder of FS801S out of my soldering. But I think it's not broken. So little bit scared to plug it in again =/
                                    Expected that with shorted MOSFETs.
                                    • sepper
                                      • Jul 2017
                                      • 32
                                      • Belgium
                                      #58
                                      I bought another powersupply from aliexpress. Well... It doesn't make the click sound anymore. But now I got no picture only sound I do got backlight and I don't see something when I shine a flashlight on it.
                                      Any tips to investigate?
                                      • sepper
                                        • Jul 2017
                                        • 32
                                        • Belgium
                                        #59
                                        Nvm. Fixed it My connection to the t-con board was not good. But now it's ok and tv is working So case closed
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                        • C152Heavy
                                          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                          • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                          • Have read ALL applicable threads
                                          • C1818 and CP820 replaced as low hanging fruit
                                          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • alltvrepairs
                                          Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
                                          by alltvrepairs
                                          I have confirmed that I have a mainboard problem.
                                          I have tracked no hardware issued on board so might be a software dump required.
                                          I have searched a bit but wasn't able to find anything for my screen:
                                          Here are some more details:
                                          Panel: cy-nn065hgev1h
                                          Main: BN94-14180M P08F
                                          Your help much appreciated!
                                          05-16-2025, 03:03 AM
