So how can you figure out what voltage your LED strips are suppose to be producing? Meaning i am trying to figure out if the LED strips are bad or PB. Panel doesnt say what voltage it is suppose to be nor did i find anything online.
What should be the Voltages LED Strips?
Tags: None
Re: What should be the Voltages LED Strips?
what is the tv make and model number? also on the metal panel on the back of the lcd there is usually a white sticker with the details of what type of lcd screen is used in the tv can you let us know what it says -
Nothing on the back of the panel. The LED strips do say 94V on them, but when measuring i only get 82-84V thats it. I do have a picture with the flashlight test. Think power supply is bad?Comment
94V is the UL compliance for flammability rating not the Vf for the LED strip.Never stop learning
There is sticker on the LCD panel some where.
http://www.shopjimmy.com/sharp-dkeym...main-board.htm
Panel Sticker Number: LK600D3HB80V, LK695D3GV00F, LK695D3GV00D
How many LEDs are there in each one of the LED string?Never stop learning
Is this your power supply/LED driver board?
You have 3 LED strings thus 3 boost converters and 3 PWM Controlled Power MOSFET for each string.
http://www.shopjimmy.com/sharp-runtk...-led-board.htmNever stop learning
by CapacitorialHello guys,
I have a Philips 240B7QPJEB. The monitor seems completely dead.
I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
The weird thing is, that the Power LED is powered over the TCON board.
On The TCON...-
12-28-2024, 02:12 PM -
Assuming...7 Photos -
by h4rdw4reHi guys,
I have one very old TV.
Main problem I have with this tv is that led strips won't light.
I measured voltage levels, and inverter input is 24V.
other voltages are also ok.
What I found is that removing and connecting again connector CN1 led strips lights for shorts time (but only once). When led strips lights up then light is uniformly spread on whole panel.
First I thought that led strips are dead, but I'm quite sure that problem is not strips related.
I don't know what voltage level is at output of inverter board (samsung SSL400_3E2A) and how... -
by edugimenoHi There!
I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the... -
by eccerr0rI suspect a lot of you have done a lot of repairs and end up with a lot of bad LED strips...what do you do with them?
Wonder if I should get a pile of LED chips and try to replace the bad units for the heck of it, but I don't really need the strips at the moment because I bought the strips...
Oh... and I think I got my TV working again, though not 100% I don't think, on a white screen I can see a bit of the ghost of the LED strips, must have done something wrong or the LED strips aren't quite the same as the original... - Loading...
