insignia ns-46e340a13 standby 7 blinks - when on, text missing on menus
+ More Options
Posts
  • cherokee.warrior
    • May 2017
    • 87
    This is a strange tv. It will not power on when pressing the power button. It gives me 7 flashes of the standby light then cycles the 7 flashes again and again. If i leave the tv plugged in it will turn on after a while all on its own. When it does turn on, the menus on the screen are missing any text. when looking at the video on the screen it seems to be slightly blurry. Any thoughts on what is going on? I have tried to find a service manual with no luck so far. Any kind of help would be appreciated.
  • kgavionics
    • Apr 2017
    • 152
    Re: insignia ns-46e340a13 standby 7 blinks - when on, text missing on menus
    Hi
    can you post some pictures please when the tv is ON.
    next step you have to take the tv apart and check visually if you have some bulging caps on power supply.
    • cherokee.warrior
      • May 2017
      • 87
      There are no bulging caps. I have tested the voltages running from the power board to the main boards. CN901.
      1 0v
      2 5.2v
      3 5.2v
      4 5.14v
      5 25.01v
      6 24.97v
      7 0v
      8 0v
      9 0v
      10 12.19v
      11 12.15v
      12 0v
      13 0v
      sorry the tv does not have a base and i was holding tv upside-down.
      • cherokee.warrior
        • May 2017
        • 87
        once tv decides to turn itself on without me doing anything theses are the voltages for cn901.
        1 0v
        2 5.19v
        3 5.19v
        4 5.12v
        5 24.7v
        6 24.7v
        7 0v
        8 0v
        9 0v
        10 12.2v
        11 12.3v
        12 3.20v
        13 4.66v
        • dskall
          • Oct 2016
          • 2905
          • usa
          Voltages mean nothing without pin discription
          • cherokee.warrior
            • May 2017
            • 87
            One of the pictures above is the connector in question. Whats in the picture is all i have. Ive been looking for a service manual with no luck.
            • dskall
              • Oct 2016
              • 2905
              • usa
              When there is no picture can you see image on screen with flashlight?
              • cherokee.warrior
                • May 2017
                • 87
                here is the connector from the under side of the board.
                • cherokee.warrior
                  • May 2017
                  • 87
                  no. it is not powering on. no image with flashlight. when it decides to turn on then i get image and sound but the menus have no test in them just graphics.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    You seem to have your ps_on but you lose your backlight signal. With your other problems sounds maybe like eeprom
                    • cherokee.warrior
                      • May 2017
                      • 87
                      I was kind of leaning that way but trying to figure out what is causing it. Here is a picture of the backside of the power board.
                      • cherokee.warrior
                        • May 2017
                        • 87
                        front view of power board.
                        • cherokee.warrior
                          • May 2017
                          • 87
                          Yes ps on I do have
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            On main board U403 is eeprom. Probably under metal shield. You could try freezing it with air duster upside down and see if it comes on.
                            I'm number one
                            • attainteddragon
                              • Apr 2013
                              • 764
                              • australia
                              you can try heating/cooling the main board to see if the missing signals come back when in fault mode, or force the fault on when it is working.
                              looks like dskall beat me to this comment. :P
                              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                              • cherokee.warrior
                                • May 2017
                                • 87
                                I can not find a u403. here are some pictures of the board with the metal cover removed.
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  First picture lower left
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    U403 as shown. What is the discolouration on the top of the IC
                                    • ugamazing
                                      820-02020 PPBUS_AON missing
                                      by ugamazing
                                      Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                      Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                      02-05-2025, 04:21 PM
                                    • jpreza
                                      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                      by jpreza
                                      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                      Looking at the card, it appears to be missing the following:
                                      1x 1.0uH inductor - orange square
                                      2x...
                                      11-01-2024, 10:54 PM
                                    • gurj1979
                                      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                      by gurj1979
                                      Hey guys.
                                      Need help with this one.
                                      Fan not spinning due to missing PWN Fan signal.
                                      Also 5 seconds from powering up it freezes, unless in BIOS.
                                      But as soon as Windows starts to load, it will freeze.
                                      CPU is COLD / Room temp when it freezes.
                                      I've replaced the CPU, same problem.
                                      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                      Replaced fan - same problem.
                                      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                      08-19-2024, 05:22 PM
                                    • salopian
                                      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                                      by salopian
                                      Hello. I would need some advice please.
                                      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                                      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                                      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                                      I have already replaced the logic board with another...
                                      02-27-2021, 07:30 AM
                                    • ein_individuum
                                      Missing Capacitator Intel I9-12900KF CPU
                                      by ein_individuum
                                      I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                                      I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                                      Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                                      08-06-2025, 01:36 AM
