insignia ns-46e340a13 standby 7 blinks - when on, text missing on menus
  • cherokee.warrior
    • May 2017
    • 87
    This is a strange tv. It will not power on when pressing the power button. It gives me 7 flashes of the standby light then cycles the 7 flashes again and again. If i leave the tv plugged in it will turn on after a while all on its own. When it does turn on, the menus on the screen are missing any text. when looking at the video on the screen it seems to be slightly blurry. Any thoughts on what is going on? I have tried to find a service manual with no luck so far. Any kind of help would be appreciated.
  • kgavionics
    • Apr 2017
    • 152
    Re: insignia ns-46e340a13 standby 7 blinks - when on, text missing on menus
    Hi
    can you post some pictures please when the tv is ON.
    next step you have to take the tv apart and check visually if you have some bulging caps on power supply.
    • cherokee.warrior
      • May 2017
      • 87
      There are no bulging caps. I have tested the voltages running from the power board to the main boards. CN901.
      1 0v
      2 5.2v
      3 5.2v
      4 5.14v
      5 25.01v
      6 24.97v
      7 0v
      8 0v
      9 0v
      10 12.19v
      11 12.15v
      12 0v
      13 0v
      sorry the tv does not have a base and i was holding tv upside-down.
      • cherokee.warrior
        • May 2017
        • 87
        once tv decides to turn itself on without me doing anything theses are the voltages for cn901.
        1 0v
        2 5.19v
        3 5.19v
        4 5.12v
        5 24.7v
        6 24.7v
        7 0v
        8 0v
        9 0v
        10 12.2v
        11 12.3v
        12 3.20v
        13 4.66v
        • dskall
          • Oct 2016
          • 2905
          • usa
          Voltages mean nothing without pin discription
          • cherokee.warrior
            • May 2017
            • 87
            One of the pictures above is the connector in question. Whats in the picture is all i have. Ive been looking for a service manual with no luck.
            • dskall
              • Oct 2016
              • 2905
              • usa
              When there is no picture can you see image on screen with flashlight?
              • cherokee.warrior
                • May 2017
                • 87
                here is the connector from the under side of the board.
                • cherokee.warrior
                  • May 2017
                  • 87
                  no. it is not powering on. no image with flashlight. when it decides to turn on then i get image and sound but the menus have no test in them just graphics.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    You seem to have your ps_on but you lose your backlight signal. With your other problems sounds maybe like eeprom
                    • cherokee.warrior
                      • May 2017
                      • 87
                      I was kind of leaning that way but trying to figure out what is causing it. Here is a picture of the backside of the power board.
                      • cherokee.warrior
                        • May 2017
                        • 87
                        front view of power board.
                        • cherokee.warrior
                          • May 2017
                          • 87
                          Yes ps on I do have
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            On main board U403 is eeprom. Probably under metal shield. You could try freezing it with air duster upside down and see if it comes on.
                            I'm number one
                            • attainteddragon
                              • Apr 2013
                              • 764
                              • australia
                              you can try heating/cooling the main board to see if the missing signals come back when in fault mode, or force the fault on when it is working.
                              looks like dskall beat me to this comment. :P
                              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                              • cherokee.warrior
                                • May 2017
                                • 87
                                I can not find a u403. here are some pictures of the board with the metal cover removed.
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  First picture lower left
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    U403 as shown. What is the discolouration on the top of the IC
