Re: visio vx37l resistor indentity help
"223J: 1000VHoX:" 0.022uf +/- 5% (J), 1000V rating. You need to remove it to check the capacitance.
BTW, you did verify that the diodes on the cold side for the 12V and 24V are OK, right?
DLA001D SMPS IC.
One of these threads should show info about the DLA001D:
https://www.badcaps.net/forum/search...archid=9081622
I'm not sure how to test c610. its labeled "phs 223J: 1000VHoX:"
I cant find the schematic on the IC its labeled "DLA00LD(or DLA001D) DEI 92UR642"
My recent tests have been with only the one cable that turns on the tv.(cn3)Leave a comment:
C610 is OK?
Look up spec of SMPS IC601 which drives the two MOSFETs fo r that T1 Transformer to see if you do have VCC to run the IC or not.
BTW, you indicate no 12V/24V, is that without having the 24V cable going to the inverter board?Last edited by budm; 07-15-2017, 04:53 PM.Leave a comment:
I had removed the transformer to gain access to the blown transistors. should i remove the transformer and test?
The problem seems to be I'm getting voltage at the drain(406Vdc) but i need 3-5Vdc at the gate that I'm not getting. It gives a quick flash ranging anywhere between .4Vdc and 2vDC.
I traced this reading to the IC pin. (IC601)Leave a comment:
BTW, I need better straight shot pictures of the WHOLE top and bottom side of that power supply board. Also did you remove one of the power transformer T1 as shown in post#1? That transformer is for 12V/24V power supplies.
This looks to be your PS board:
http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
Vizio 0500-0507-0250 (DPS-247APB) Power Supply Unit.Last edited by budm; 07-15-2017, 03:09 PM.Leave a comment:
OK I don't know why I was getting those reading before but i teste dit again and I'm getting 162Vdc across the filter cap in standby( which is PFC correct?) and then bumbs up to 406Vdc when i push the power button.
something is up with the transistor circuit.
Reference the second picture at the top. top of the boardLeave a comment:
ummm soo yeah using the negative leg of main filter cap got me 528Vdc on the cathode of that diode. and 406Vdc on the anode.
I don't get it.
With the device in standby i have 194Vdc on the cathode of the diode
.Last edited by sdinelli; 07-15-2017, 10:23 AM.Leave a comment:
Thank you for the info guys. hot and cold sides confuse meLeave a comment:
It will block half the cycle of the feeding AC in rectifying circuit.
http://www.visionics.a.se/html/curri...ectifier1.htmlLeave a comment:
a diode will block ac, so when checking voltages on the cathode, you test in dc.Leave a comment:
Negative leg of the main filter cap is the GND ref. for the primary side of the circuit.Leave a comment:
yeah I thought it sounded high. lol should I be using the negative side of the main cap?
should I measure ac or dc?Leave a comment:
Sounds like using the wrong GND Ref. for the meter.Leave a comment:
SO I replaced the 2 transistors and the resistor.
Now I have standby
psON is up at 4.6V and visio turns from amber to white
BUT I'm only getting about 1-2V on my 12V and 24V
I checked and I'm getting 472Vdc on the big diode (ZD902) behind the transformer in the picture.
Any suggestions?
Also, theres a faint buzzing coming from the new transistors I installed. doesnt that mean the voltage is too low or something?Last edited by sdinelli; 07-09-2017, 08:20 PM.Leave a comment:
sorry for being MIA. Busy Weekend.
Now that you say it. I think you all are right.
For the next $million question..........
How far do you think the damage went?
I have R623 reading 4.8ohms
R621A = 24.6ohms
R62B = 15.7ohms
R618 & R620 (resistors between source and gate) are 20kohms
reading 19.93ohm and 20ohms
What else should I check?
what are the chances the surge blew back into IC 601
thanks for the help amigosLeave a comment:
Ah well ; No , i don't have the board , but i have the schematic , and frankly , this one came with many restrictions and warnings considering publishing . That's all..Leave a comment:
I'm not the original poster.Not after one, I just wanted to know if you had one of these boards and confirmed it was that .
You seemed very certain.Leave a comment:
by mikey5791Hi to all forum members,
Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors... -
by artvandalaiThe resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y3 Photos
by chth96I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
Since then, This AC/DC adaptor have been out of order.
But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
And Is there any possibility that it will suddenly explode as well as to be out... - Loading...
