visio vx37l resistor indentity help
  • sdinelli
    Sdinelli
    • Aug 2014
    • 152
    tv model: vx37lhdtv20A
    power supply: DPS-247APB
    no standby power
    found two transistors shorted all ways (model STP12NM50FP )
    found one resistor burned up
    resistor Is burned right where the ohm is printed and I cant read it.
    I need help trying to figure out the value.
    It says "F1J' and also what looks like some symbol &"60B"
    The resistor goes from the positive side of main filter cap and connects to the drain of one of the blown transistors as well as one leg of a transformer
    PLease help If possible
    Re: visio vx37l resistor indentity help
    That is the fusible resistor, probably <1 Ohm range.
    • sdinelli
      Sdinelli
      • Aug 2014
      • 152
      thank you
      would you be able to recommend a replacement?
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Can you put a picture and some mark on the location of this F1J ?
        • tw2005
          • Oct 2011
          • 6458
          R805 I would say.
          I'll have a guess. First symbol is looking like a R so 0.? And the number has a curve so I'm thinking a 2 or 3. I'm going with 3 So 0.3 ohm.
          Let me know what the prize is if I'm correct.
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            Originally posted by tw2005
            R805 I would say.
            Yes , It is labeled R3Ω ,so it's 0.3 Ω. You're a winner ..
            • tw2005
              • Oct 2011
              • 6458
              Do you have a live one in captivity to refer to? LOL.
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                In my stock of used parts , i'm sure i can find a dozen , but still , Lebanon is very far , unless you wanna wait ..
                In case you didn't find it , i'm ready , send me your E-mail
                • tw2005
                  • Oct 2011
                  • 6458
                  I'm not the original poster.Not after one, I just wanted to know if you had one of these boards and confirmed it was that .
                  You seemed very certain.
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    Ah well ; No , i don't have the board , but i have the schematic , and frankly , this one came with many restrictions and warnings considering publishing . That's all..
                    • sdinelli
                      Sdinelli
                      • Aug 2014
                      • 152
                      sorry for being MIA. Busy Weekend.
                      Now that you say it. I think you all are right.
                      For the next $million question..........
                      How far do you think the damage went?
                      I have R623 reading 4.8ohms
                      R621A = 24.6ohms
                      R62B = 15.7ohms
                      R618 & R620 (resistors between source and gate) are 20kohms
                      reading 19.93ohm and 20ohms
                      What else should I check?
                      what are the chances the surge blew back into IC 601
                      thanks for the help amigos
                      • sdinelli
                        Sdinelli
                        • Aug 2014
                        • 152
                        SO I replaced the 2 transistors and the resistor.
                        Now I have standby
                        psON is up at 4.6V and visio turns from amber to white
                        BUT I'm only getting about 1-2V on my 12V and 24V
                        I checked and I'm getting 472Vdc on the big diode (ZD902) behind the transformer in the picture.
                        Any suggestions?
                        Also, theres a faint buzzing coming from the new transistors I installed. doesnt that mean the voltage is too low or something?
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          472v seems rather high
                            Sounds like using the wrong GND Ref. for the meter.
                            • sdinelli
                              Sdinelli
                              • Aug 2014
                              • 152
                              yeah I thought it sounded high. lol should I be using the negative side of the main cap?
                              should I measure ac or dc?
                                Negative leg of the main filter cap is the GND ref. for the primary side of the circuit.
                                • attainteddragon
                                  • Apr 2013
                                  • 764
                                  • australia
                                  a diode will block ac, so when checking voltages on the cathode, you test in dc.
                                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                                    It will block half the cycle of the feeding AC in rectifying circuit.
                                    http://www.visionics.a.se/html/curri...ectifier1.html
                                    • sdinelli
                                      Sdinelli
                                      • Aug 2014
                                      • 152
                                      Thank you for the info guys. hot and cold sides confuse me
                                      • sdinelli
                                        Sdinelli
                                        • Aug 2014
                                        • 152
                                        ummm soo yeah using the negative leg of main filter cap got me 528Vdc on the cathode of that diode. and 406Vdc on the anode.
                                        I don't get it.
                                        With the device in standby i have 194Vdc on the cathode of the diode
                                        • mikey5791
                                          by mikey5791
                                          Hi to all forum members,
                                          12-26-2024, 04:55 AM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • chth96
                                          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                          by chth96
                                          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                          Since then, This AC/DC adaptor have been out of order.
                                          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                          And Is there any possibility that it will suddenly explode as well as to be out...
                                          12-03-2023, 04:40 AM
