Samsung LA32C400 stuck in standby, red light on.
  • Cap-tivated
    • Jun 2017
    • 12
    • Thailand
    With reference to the thread...
    Here
    I'm wanting to repair multiple Samsung LA32C400 TVs. (Shares the same PSU as LE32C450)
    Most have the same fault as described by the OP in the thread above.
    I have not tested the actual psu boards but doning one from a fully working set does do the trick.
    PSU board is again the BN440033A version (not B).
    Soooooooo,
    Q1) Is it safe to assume that the same brown poly cap as shown by martino is the one to attack on each of these faulty sets?
    Q2) Another set comes on fine but once warmed for a minute or so has horizontal "interference" lines along the top third of the screen. What should I be looking at to fault find this?
    Many thanks.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung LA32C400 stuck in standby, red light on.
    A1) Can you do a self-test on the PSU using the car bulbs as dummy loads? If that works then I would still go ahead and replace the brown poly cap then go on to suspect the Main Bd.
    A2) Lines on the screen most likely bad tab bonds or perhaps either the cut-off or the bypass method may be applicable.
    Please post some clearly focused close up pictures of the screen problem and the PSU, so the experts can help you better.
    • CapLeaker
      Leaking Member
      • 8352
      Any pictures?
      • Cap-tivated
        • Jun 2017
        • 12
        • Thailand
        Thanks for the replies.
        I can answer just one point right this minute which is a photo of the psu. I'll follow up with more.
          Can we see higher res pictures of that power supply board and also the whole back of the TV showing all the boards.
          I cannot read the board P/N. BN44-??????
          "BN440033A version (not B)" as posted is not valid number.
          I cannot read the labels for each pin of the connectors or the Voltage charts as printed on the board either.
          • Cap-tivated
            • Jun 2017
            • 12
            • Thailand
            Ah, looks like my phone and PB defaulted to low res, try again.
            I'll do the rest later.
              How about the pictures of the whole backside of the TV showing all the boards?
              So the power supply board is BN44-00338A.
              "Q2) Another set comes on fine but once warmed for a minute or so has horizontal "interference" lines along the top third of the screen. What should I be looking at to fault find this?" We still need the screen shot of what you are seeing.
              • vinceroger69
                • Mar 2012
                • 6714
                psu schematic
                • Cap-tivated
                  • Jun 2017
                  • 12
                  • Thailand
                  Here are the rest of the photos as requested.
                  Thanks to vr69 for the schematic.
                  Control board
                  Inverter board
                  Then finally the screen shot from my Q2
                  • Cap-tivated
                    • Jun 2017
                    • 12
                    • Thailand
                    Realised I hadn't conformed to picture requirements so here they are attached this time...
                    • Cap-tivated
                      • Jun 2017
                      • 12
                      • Thailand
                      I didn't have any car bulbs to hand so haven't tried that test until I grab some.
                      "A2) Lines on the screen most likely bad tab bonds"
                      What's the method for checking the tab bonds?
                      "or perhaps either the cut-off or the bypass method may be applicable."
                      Could you explain or link to these methods please.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        As your tv has the lcd panel pcb and tab bonds at the bottom of the tv theres also a chance someone has used cleaner on the screen and possibly damaged the tab bonds im also not sure if a main board bga chip can cause this issue hopefully a more experienced member will confirm the video i linked shows bad tab bond issues but these i notice all have vertical lines your has horizontal lines i know budm has fixed his own samsung tvs with tab bond issues maybe he can advise you
                        https://www.youtube.com/watch?v=j7vl7-vZEL8
                        • Cap-tivated
                          • Jun 2017
                          • 12
                          • Thailand
                          Thanks again vc69!
                          I'll be giving that a go the first chance I get on the single TV with the lines and double image.
                          • attainteddragon
                            • Apr 2013
                            • 764
                            • australia
                            double imaging can be caused by tab bonds, so it could be panel.
                            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                            • Cap-tivated
                              • Jun 2017
                              • 12
                              • Thailand
                              Ok, I gave the connecting ribbon my best shot for curing double image and lines but no matter what I did there was absolutely no difference, better or worse.
                              On this model set there is no separate TCON board that devides the screen into two halves with a ribbon for each. Therefore, I was trying this on the single ribbon leading directly to the board attached to the bottom edge of the screen.
                              For now I've swiped its PSU to use in one of the other sets that was stuck in standby.
                              I have confirmed the brown poly on the PSU boards as being a 1000v 22nf 5% (223J).
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                To get too the lcd panel tab bonds it will require stripping the tv rite down but theres alaways a risk of cracking the lcd panel or making the set even worse as its a combined mainboard and t con board i wonder if it this at fault i was hoping a more experienced member may chime in with there thoughts etc
                                • Cap-tivated
                                  • Jun 2017
                                  • 12
                                  • Thailand
                                  That's exactly why I only went as far as loosening the frame a little at the base end so I could sneak a peek at was there. I couldn't see any more ribbons in there, just the same single ribbon connecting to what must be a combined board, very narrow, running most of the width of the screen.
                                  Having failed miserably on a laptop screen repair (full dismantle for illumination problems) before I opted to stop there!
                                  • Cap-tivated
                                    • Jun 2017
                                    • 12
                                    • Thailand
                                    Does anybody have further thoughts for a fix to the combo board as discussed above. Off to buy some poly caps tomorrow so hopefully other sets will be back on line, just leaving this one with lines and double image.
                                    • Folxs
                                      • Nov 2016
                                      • 167
                                      • Poland
                                      I'm searching for schematic of Samsung BN44-00330A - froma Plasma 42"TV
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        please ignore just realized yours is a BN44-00330A and not a bn44-00330b
                                        http://electro-medical.blogspot.co.u...ply-board.html
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
                                        • marcinq
                                          Samsung UE60KS7000 No Standby Light
                                          by marcinq
                                          I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                                          I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                                          05-26-2025, 11:36 AM
                                        • SJX1290
                                          No Standby Light on Samsung SAMSUNG UE65NU7022
                                          by SJX1290
                                          I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
                                          My main suspect is bad flash memory, ...
                                          Any suggestions or can someone please​ check dump file, in the attachment
                                          Thank you...
                                          09-07-2024, 01:35 AM
