Lg 32ls575t
  • joehezzer
    • Jul 2012
    • 251
    • England
    Lg 32ls575t
    Hi all I have lg 32 ls 575 t. Iam getting issues with vertical lines. Pinky/black lines. It doesn't do anything, input dont do anything and cannot change channel. Cheers picture supplied
  • CapLeaker
    Leaking Member
    • 8146
    Re: Lg 32ls575t
    I'd be verifying the LVDS cable with an oscilloscope, to see if the main board is good to start with.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Re: Lg 32ls575t
      Almost like it is stuck in test pattern
      • joehezzer
        • Jul 2012
        • 251
        • England
        Re: Lg 32ls575t
        I did wonder that myself tbh
        • joehezzer
          • Jul 2012
          • 251
          • England
          Re: Lg 32ls575t
          Might have a dig around see I have another around
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • Syseng
            Lenovo P14s Gen 5 SVP unlock
            by Syseng
            This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
            The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
            06-22-2025, 07:44 AM
          • dicky96
            American Audio VLP1500 Distorting on one channel
            by dicky96
            Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
            Protection and Clip LED are off
            There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
            I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
            The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
            07-13-2022, 05:25 AM
