Dustiest Tv Ever ?
Dustiest Tv Ever ?
https://www.facebook.com/Telford-Tel...7894576335359/Tags: None -
Re: Dustiest Tv Ever ?
I thought the same. I work at home too, but not in my bedroom. I enabled a room as workshop and everything is done here. I just use the bed sometimes to keep a LCD glass while I work on LED backlight, for instance. But I wouldn't disassemble anything over my own bed. Well, I guess it's an unused bedroom in Reecey's home, but anyway I'd have replaced that bed with a table or bench.Comment
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Its an unused room my mom sleeps in there every so often but shes got a new roomI thought the same. I work at home too, but not in my bedroom. I enabled a room as workshop and everything is done here. I just use the bed sometimes to keep a LCD glass while I work on LED backlight, for instance. But I wouldn't disassemble anything over my own bed. Well, I guess it's an unused bedroom in Reecey's home, but anyway I'd have replaced that bed with a table or bench.
Ive actually a really good video to upload, I found a FUCKING PANCAKE in a Tv a few months back anyone who has me on facebook would have seen will upload it soon
WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Not a long ago a guy from a bar brought me a Sony CD player to repair. An hour later I saw a cockroach walking on my bench, and the same evening I saw another one running in the floor. At that time I was unsure if both events were connected, so I didn't tell anything... until I returned the CD player to the bar. The bartender opened the place for me, and when he turned the lights on, I realized I was surrounded by hundred tiny cockroaches!!
Then it was clear that I was lucky to get only two passengers with the CD.
I think that every technician has stories like this.Comment
by odononoI made a post over on reddit about how my windows laptop only works when plugged in now, because I dropped a screw driver on the connector pins where the laptop battery plugs into, causing sparks. I put a brand new battery in but still the same result, so something on the board obviously got fried (however, there's no visible burn marks, so no clue what was affected). I honestly wouldn't care, but my laptop is power throttling even with the internal battery unplugged (turns out this is a common problem on laptops with poor batteries or missing batteries). The GPU won't go above 40W when the TDP...
by unimatrix93Hello everyone,
What software do you guys recommend me to manage my repair projects and customers?
Is there any free or opensource solution or I should stick to using Excel until I can invest into a proper software?
Thank you!-
by myth77When i need to replace cpu or gpu or pch ...i mostly order reballed chip from china, but lately there are more broken ones then working.
So lately i tried with ebay "not working motherboards". I ordered a few broken motherboards from ebay but i have found out that there are many scammers on ebay. The most of them are selling already destroyed motherboards with pictures in low resolution, some of them are being scammed and just scam forwarding...
First board i ordered last month was ok. Cpu was dead but i could use gpu and pch. The second arrived 2 weeks ago...and it was... -
by koby058Hi all
I s there a list of must have charging IC in repair shop. versions you must have in stock?
I mean the most "popular" / widely used in laptops. -
by koby058Hi
I have ordered a set of ceramic caps from a..express and when i measure a 10uf cap the multi meter showed 8uf, I guess those are shitty caps.
Can you recommend where to buy high quality caps and fuses
ali is preferred if possible - Loading...
