must have charging IC in repair shop
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi all
    I s there a list of must have charging IC in repair shop. versions you must have in stock?
    I mean the most "popular" / widely used in laptops.
  • Udemzy
    • May 2017
    • 168
    • Guatemala
    Re: must have charging IC in repair shop
    Bq24780s
    is a must have
      • 22182
      Originally posted by koby058
      Hi all
      https://www.badcaps.net/forum/showthread.php?t=84817
      • koby058
        • Jan 2017
        • 387
        • israel
        Thanks for the detailed reply
        Is it safe to buy those in aliexpress or there can be copies ?
        • mon2
          • 14758
          Not all shops are evil but there are some out there.
          Here is one that we have used many times and trust them to buy again:
          https://www.aliexpress.com/item/3289...17668616%21sea
          Also, often the shop will source other parts on your behalf to save you money on shipping. Just install the Aliexpress app on your phone / PC and chat with them before ordering. You are also protected by the Aliexpress team for the most part but if you use your credit card, even better with their level of protection.
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            Also used this shop for all my IC shopping, never had a problem.
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • Thomasraud
              Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
              by Thomasraud
              i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
              QUOTED
              -It works on charger (without battery connected-only charger)
              -It works on battery (without charger connected-only battery)
              -& it also works when plugged in battery & charger, but it's not charging the battery
              //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
              and..
              QUOTE
              The IC cannot maintain the input current level
              06-28-2022, 06:47 PM
            • Scoff
              HP Probook 470 G4 - Power and Charging Problem
              by Scoff
              Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
              Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
              07-03-2023, 09:28 AM
            • SluggerB
              Help with trying to fix phone that is not charging (Pics inside)
              by SluggerB
              I have two TCL A30 phones.
              Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
              New Phone: Works fine, bought as a donor board to try and repair Old Phone
              My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
              08-12-2024, 08:11 AM
            • Wang Tingting
              Acer Nitro 5 AN515-57-536Q not charging
              by Wang Tingting
              I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
              report is also good for battery.
              Following https://www.badcaps.net/forum/troubl...arging-circuit,
              • DCIN/VCC: 19.1
              • ACIN/ACDET: 3v
              • REGN/VDD: 6v
              • CMSRC : 19v
              • ACOK: 3.3v
              • ACDRV: it is 19v, not 25V(when charging, the ACDRV
              09-10-2025, 01:46 PM
