capacitor stock for repair shop
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi
    I have ordered a set of ceramic caps from a..express and when i measure a 10uf cap the multi meter showed 8uf, I guess those are shitty caps.
    Can you recommend where to buy high quality caps and fuses
    ali is preferred if possible
  • mon2
    • 14735
    Re: capacitor stock for repair shop
    The capacitance is only an approximate value. Some parts have different tolerance than others. Factors such as the quality of your meter will play a role in the final measurement.
    Guessing that the parts you have are 20% tolerance.
    Parts do derate based on their physical size and the actual voltage for which is used in the circuit compared to the rated voltage.
    Read this eye opener of an article:
    https://www.maximintegrated.com/en/d...ls/5/5527.html
    • piernov
      • Jan 2016
      • 4439
      • France
      Indeed capacitors are generally 20% tolerance, and capacitance measurement in a DMM is not necessarily very accurate. However if they are very close to the 20% tolerance bounds (so very close or below 8uF), they may be "refurbished" old capacitors that have aged already. In general it's not a problem, but if you want a reliable supply of parts, don't use Aliexpress, buy from a local electronics distributor.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
