HISENSE LTDN65k560XWAU3D red light blinking
  • buchman
    • Aug 2015
    • 294
    • greece
    Hi guys,
    please help, got it from a friend and I want to fix this TV so badly.
    It's a 65" smart 3D tv.
    The red light blinks once in a second and doesn't stop.
    Checked volteges on the connector and I don't get them.
    The fuse is fine. no bulged caps. I measure 315 VDC on the rectifier, is that OK?
    PLEASE guys I want to fix it soooooo badly!
    THANKS IN ADVANCE.
  • buchman
    • Aug 2015
    • 294
    • greece
    Re: HISENSE LTDN65k560XWAU3D red light blinking
    The connector is circled in red
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      what voltages do you have on xb803, in standby and when you try to power it on.
      a pic of the entire back of the tv would be nice too.
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      • buchman
        • Aug 2015
        • 294
        • greece
        I will post the volteges later.
        • buchman
          • Aug 2015
          • 294
          • greece
          First, here are two picture while I am measuring capacitors with my ESR meter.
          I have 2 different measurements. Is that OK?
          Second, on XP803 connector I have the following volteges(with connectors XP802 and XP804 disconnected, only the AC plug connected):
          18V-0
          18V- 0
          GND-0
          STB-0
          12V- fluctuate fast between 11.37-12.2
          SW-0
          BRI-0
          GND-0
          GND-0
          On connectors XP802 and XP804 the voltege fluctuate fast between 3-77 volts on the 24V pins. (with connectors disconnected).
          On pins I01, I02, I03, I04 it show 0 volts.
            Do not bother to check those two blue safety caps.
            What DCV do have on the blue lytics cap (C922) laying on its side next to inductor L921 when measured right between the two legs of the cap?
            So what DCV do you get at the STB (PS-ON) when power switch is activated?
            BTW, do not try to test ESR when the cap is still in the circuit due to the fact it has other component connected in parallel the cap being measured, and the ESR meter is not made for that kind of caps anyway.
            • Diah
              • Feb 2013
              • 6596
              disconnect both socket xp204 & xp202 , check the 12 volts on the socket xp605 i think, the one connected to main board , it could be high to 13Volts. tell result
              • buchman
                • Aug 2015
                • 294
                • greece
                On the C922 cap the voltege fluctuate fast between 11.3-12.2.
                What do you mean when power switch activated? Do you mean when I press the red button on the remote control to turn on the tv?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  When you press button to turn tv on what voltage do you get on STB pin?
                  • buchman
                    • Aug 2015
                    • 294
                    • greece
                    I am sorry but I don't see the sockets that you mentioned.
                    • buchman
                      • Aug 2015
                      • 294
                      • greece
                      Thanks for the clarification. I will check that and post the result.
                      • buchman
                        • Aug 2015
                        • 294
                        • greece
                        Here are the findings.
                        First, with all connectors connected the STB voltege fluctuate between 0.3-1.8 volts.
                        When press the power switch nothing happens and the voltege on the STB continues to fluctuate.
                        second, if XP802 and XP804 disconnected then the voltege on the XP803 connector on the 18V pin show zero but, if the XP802 and XP804 are connected then the voltege fluctuate on the 18V pin.
                        • buchman
                          • Aug 2015
                          • 294
                          • greece
                          May be I can start checking voltages across different components to see where Is the voltage stuck but I need help with that. where to check exactly and what are the readings should be?
                          • buchman
                            • Aug 2015
                            • 294
                            • greece
                            anyone?
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              On back of board what number is on N85?. Right of main caps
                              • rosatdomains2
                                • Oct 2019
                                • 3
                                • Nigeria
                                Hello i am having same problem LTDN65K560XWAU3D. my tv is just stopped working. i opened it and checked. found out a liked cap. I changed it and now red light led is just blinking. no voltages 18v, 24, i only have 12v
                                • rosatdomains2
                                  • Oct 2019
                                  • 3
                                  • Nigeria
                                  HI I have been searching everywhere for the schematics for LTDN65k560XWAU3D. can anyone help me find one?
                                  • Deshan
                                    • Dec 2019
                                    • South Africa
                                    Hi everyone, also have same model. HISENSE LTDN65k560XWAU3D, I find it difficult to trace without service manual or schematic.. Anyone found one yet? How to confirm if NB851 is faulty or in protection mode?
                                    Currently I have no voltages, 24v, 18v, 12v, STB, don't even know if I'm on the right path or not..
                                      • 12331
                                      • U.S.
                                      Check all diodes on powerboard, tv unplugged from power.
                                      • YasaCh
                                        Sony kdl 40p5500 red light keeps blinking 3 times
                                        by YasaCh
                                        Hello...
                                        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                        i opened the back cover no sign of damage on the powery suply or motherboard
                                        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                        07-07-2025, 11:53 AM
                                      • Fergal22
                                        Samsung UE40F5300AK blinking red light
                                        by Fergal22
                                        I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                        When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                        I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                        Any help would be appreciated...
                                        02-02-2023, 09:19 AM
                                      • matty24
                                        Samsung UE50MU6172 - red light blinking
                                        by matty24
                                        Hello. I have problem with Samsung UE50MU6172.
                                        TV won't turn on, red standby light is blinking.
                                        Power supply BN44-00807A is fine. I replaced it with the new one.​
                                        Main board BN41-02568B (BN94-12530E)
                                        I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                        03-02-2025, 08:57 AM
                                      • norbiszoke
                                        Samsung 50AU7172, only blinking red light
                                        by norbiszoke
                                        We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                        Regards, Norbert!...
                                        04-17-2024, 06:54 AM
                                      • 1centchips
                                        Asus rog strix g1614jv-Is96 freezes at random times and blinking charging light
                                        by 1centchips
                                        I have the i9 version. I have tried disabling intel and Nvidia graphics in the device manager.
                                        The laptop is just out of warranty.
                                        The laptop continues to freeze randomly with the blinking amber charging light.
                                        What could be possibly wrong with it?
                                        I have also disable armoury crate in bios.
                                        12-17-2024, 05:18 PM
