Hitachi LE55A6R9 LED Issue or?
  • LITEZONER
    GO BOLTS!
    • Mar 2010
    • 223
    Re: Hitachi LE55A6R9 LED Issue or?
    chassis to diodes 267 volts each.
    39 Soldering Iron burns And Counting
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      #42
      Originally posted by LITEZONER
      well this thing is wearing me out, Led tester on red and black string wires all led's light up, no voltage coming from terminal with red/blk wires, so i think LED driver circuit not working, checked all voltages across terminal plug and get all 12V and 3V working fine, Not sure what to check next.,
      Are the two diode connected to the led output connector. They may be connected via 0 ohm resistors. Cannot tell from the pictures but you say you have no voltage on the red/black wires but 267V on the diodes which I would have though would be the led supply.
      • LITEZONER
        GO BOLTS!
        • Mar 2010
        • 223
        I will check, thank you
        • LITEZONER
          GO BOLTS!
          • Mar 2010
          • 223
          I get continuity at the depicted places, not sure about 0 ohm resistors not even sure why there would be such a thing as a 0 ohm resistor???
            You need to check the DCV at the LED connectors with ref. to Chassis GND.
            https://www.badcaps.net/forum/attach...9&d=1498138335
            Based on the picture, report the DCV staring from the top red wire:
            Top red wire =
            Blck wire =
            Red wire =
            White wire =
            So far it looks like you have open circuit in the LED string.
            • LITEZONER
              GO BOLTS!
              • Mar 2010
              • 223
              okay I will get you those readings, all the led strings have been replaced, I guess shop jimmy could have sent out a defective one? they all light up with testing on the red and black wire with my led tester and shows 90 Volts being the draw. I will put this back on and get the readings and post them in the am. thank you
              • LITEZONER
                GO BOLTS!
                • Mar 2010
                • 223
                chassis ground-/ pos + to terminals
                Top red wire = 267 V
                Blck wire = 187 V
                Red wire = 187 V
                White wire = 0 V
                • jetadm123
                  • 2169
                  #48
                  0 ohm resistors are generally used as a jumper.
                  • LITEZONER
                    GO BOLTS!
                    • Mar 2010
                    • 223
                    there are a few of these on the board.
                    • LITEZONER
                      GO BOLTS!
                      • Mar 2010
                      • 223
                      Sure hope it's not an open LED circuit in the new strips somewhere, here is the reply i received from SJ on replacement set.
                      Hello
                      Sorry to hear that's the case! Unfortunately we do not currently have these strips available to replace for you, we likely won't see more for another 1-2 months. Happy to take this back for a full refund of course. You can head here; (Omitted) to set up a return for refund and print a prepaid USPS shipping label to cover the return shipping back to us. Don't hesitate to ask if you have any questions on this.
                      Regards,
                      Austin Manning
                      Customer Service
                        Blck wire = 187 V
                        Red wire = 187 V
                        White wire = 0 V
                        The LED string with Red/White wire does not look right. Did you use the LED tester to test both LED strings by applying the tester to each LED connector?
                        • LITEZONER
                          GO BOLTS!
                          • Mar 2010
                          • 223
                          I put POS+ and NEG- across red and black, and panel lights up??? should I test each wire with ground to chassis?
                          • LITEZONER
                            GO BOLTS!
                            • Mar 2010
                            • 223
                            tried post 52 and have nothing.
                              But how about the second LED string, the one connected to the Red (Anode) and White (Cathode) Wires?
                                ??? But you indicated that LED lights up.
                                • LITEZONER
                                  GO BOLTS!
                                  • Mar 2010
                                  • 223
                                  whole panel lights up only with led tester probes on red and black wires, red and white does nothing when led tester probes are placed on these two
                                    Well, that means the LED string connected to the RED/WHITE wires is dead, you have two LED strings connected in series as you can see how they are connected by looking at the bottom side of the board where the two LED connectors are.
                                    https://www.badcaps.net/forum/attach...5&d=1498188398
                                    • LITEZONER
                                      GO BOLTS!
                                      • Mar 2010
                                      • 223
                                      well that's not good news, :-( I will tear it back down and see what i can find. will post findings in a bit, Thank you budm and everybody for all your help, Much appreciate this site. and all the great people willing to lend a hand, not too common these days so i'm grateful.
                                      • LITEZONER
                                        GO BOLTS!
                                        • Mar 2010
                                        • 223
                                        I wanted to show how these wires R/B and R/W go to the led's
                                        • LITEZONER
                                          GO BOLTS!
                                          • Mar 2010
                                          • 223
                                          well perplexed a bit, every led on the string that would not light tested good individually, but the string would not light as a whole, I replaced it with a used one i had from the old set, now were cooking i think, will post final results when assembled and working. remember, this was a brand new set of LED strips ordered from a reputable company, SJ, Lesson here, TEST,TEST,TEST, even if it is brand new, it would have taking me a few seconds to check this before spending all the time. trying to figure this thing out, assembly, disassembly, and wasting other folks time as well. Valuable lesson learned here.
                                          • yaya3gmax
                                            Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                            by yaya3gmax
                                            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                            Symptoms:
                                            • Laptop works normally on a pre-charged battery.
                                            • Battery does not charge when adapter is connected.
                                            • Without battery:
                                              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                              • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                            08-21-2025, 07:16 AM
                                          • Robin21
                                            Ubiquiti US-48-500W – No LAN Port LEDs, Possible 12V Issue?
                                            by Robin21
                                            I’ve got a Ubiquiti switch (model US-48-500W, motherboard: USW48P_BCM) on my bench. The switch powers on, but none of the LEDs next to the LAN ports light up.
                                            I’ve measured voltages across the board and suspect a problem with the 12V rail. At the coils where I’d expect 12V, I’m seeing around 6.3V. One coil shows a stable 6.378V, while the other fluctuates between 6.270V and 6.310V.
                                            All other voltages seem fine — 1V, 3.3V, and 5V are present and match the expected values.
                                            I've replaces both buck regulators already (AOZ1212)...
                                            09-25-2025, 03:24 AM
                                          • MDY94
                                            Hitachi 50HK6100U display issue
                                            by MDY94
                                            I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
                                            12-18-2024, 12:31 PM
                                          • navagator
                                            Hitachi 57F710E Power Issue
                                            by navagator
                                            I have a Hitachi 57F710E Rear Projection TV that was working great until 3 or 4 days ago. I came in and tried to turn it on and it was just dead. So, I unplugged it and plugged it back in. Nothing, not even the slight click that it makes when you plug it in. So, I removed the power supply board (It's a vertically mounted board, I believe model HA01312) and inspected it visually for bulged caps or burnt or overheated components, anything that didn't look right and couldn't find anything.
                                            I noticed on the bottom of the board there was a row of solder joints with voltages printed next...
                                            11-09-2023, 06:05 PM
                                          • AJ847.63e
                                            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                            by AJ847.63e
                                            Hi Folks,
                                            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                            05-06-2025, 10:37 PM
