I have a LG 55LA6200 when turned on the backlight turns on the LG logo is displayed then immediately turns off, all inputs and sound function appropriately and verified the image is displayed on the screen with a flashlight. When it turns on the LED power output from the PCB reads a voltage which seems to hit 9V for a second (my multimeter may not be able to refresh fast enough to read the max voltage supplied) but when the backlight turns off the voltage drops to zero. When i turn the TV off disconnect LED power connector and plug it back in the voltages remain the same, power is present for a second the drops to zero. I already tried a new PSB with the same results so wanted to check here to see what you guys think before I order a new main board, I figured since there is no voltage when the LED power output is both connected and disconnected it wouldn't be bad LED strips? Thanks in advance for any help!
LG 55LA6200 Backlight Issue?
Re: LG 55LA6200 Backlight Issue?
We need good clear straight shot pictures of the boards and the whole backside of the TV showing how all the boards are connected together.
We need to find out if the LED driver is getting the BL-ON and Dimming signals from the main board or not and also some other Voltages as well.
There are more than one versions of the TV.
http://www.shopjimmy.com/catalogsear...?q=LG+55LA6200
I.E. this power supply board:
http://www.shopjimmy.com/lg-eay62709...-led-board.htm
the Voltage at the LED+ pin (the ANODE of the LED strings) should be around 76V with load, you will have to put black probe on GND and red probe on LED+ THEN turn the TV on to see how high it goes up to.
The 9V reading made at which pin of the LED connector?Last edited by budm; 05-09-2017, 10:15 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
EBT62368508 is the main board. The Power supply board is not the one you linked to it does not have the two connectors it has this board:
http://www.shopjimmy.com/lg-eay62810...upply-unit.htmComment
Here is a photo of the inside, it is from another thread on the forum but its identical to the board set / wiring. The post its from (LG-55LA6205 backlight issues) is just the European model and have already searched and the boards themselves are interchangeable.
So it has two LED strings, the output Voltage for the LED strings is over 100 Volts per chart printed on the board.
So follow the instruction on post 2 check DCV @ the LED + as instructed and the control signals. Your meter should be fast enough to catch over 100V swing.
We will not be surprised if it has bad LEDs.
LG EAY62810701 (3PAGC10124A-R) PS.
Connector P201:
PWR-ON = PS-ON
DRV-ON = BL-ON
PDIM1 = PWM Dimming 1
PDIM2 = PWM Dimming 2
Pictures provided by shopjimmy.Last edited by budm; 05-09-2017, 11:13 PM.Never stop learning
Ok, I will do this tomorrow morning. The guy in the post I referred to about the photo disappeared after a reply said he had bad/cold solder joints on the LED strip to strip connectors so I think I'm also going to check that out too... Thanks for the help!Comment
Ok, thanks for the information as the situation has changed at the led power connector P801, I had grounding issues which resulted in incorrect readings. There seems to be something going on with the first LED- at P801 as the voltage spikes then drops but I listed both the asked for voltages at P201 and updated voltage details at P801 below:
VDC at P201:
3.4 - PWR-ON = PS-ON
3.4 - DRV-ON = BL-ON
3.5 - PDIM1 = PWM Dimming 1
3.5 - PDIM2 = PWM Dimming 2
VDC at P801 (Power On):
LED- *: 101 @ power on then drops to zero within 5 seconds of the backlight going off
LED+ : 87 @ power on and is stable within 1 VDC
LED- : 10 @ power on and is stable at 10 with little no fluctuation
VDC at P801 when powered OFF:
LED- *: Remains Zero
LED+ : Drops to 30 quickly and slowly drops to zero within 1 min
LED- : Drops instantly to Zero
LED+ : Drops to 30 quickly and slowly drops to zero within 1 minComment
"VDC at P801 (Power On):
Both LED+ are tied together and fed by the Voltage booster output.
There is no way this LED- which is the Cathode return of the the LED string to be higher than the LED+ feeding Voltage.
But at this point it does look like you do have LEDs problem.Never stop learning
Faulty LED string , remove screen and check ,replace faulty stripsComment
Following this forum with the same symtoms but different tv (LG 55LN5700-UH), I am about to check voltages at the power supply/led driver connections (LED +). I get 84.4 at both LED+ either with LED connected or diconnected, at first second of two, the voltage reads 200v at first LED+ and 123v at second LED+, then both voltages go down gradually and stabilize at 84.4. Is this an indication of bad LED backlights? Or bad powersupply/led driver board? Any assistance will help and is appreciated.Comment
You need to leave the black probe on the chassis, red probe on LED - one at time, then watch the meter when you turn on the TV to see what you get on the LED -, repeat the test on other LED -.
More likely you will find bad LEDs.Never stop learning
I have the same issue with the backlight flash, then no picture. I actually got to the backlights, and tested them. They all lit up, so I thought it was the power supply board (LG EAY62810701). After ordering a replacement board, still had the same issue, so I tested all of the voltages per this thread. Any feedback would be much appreciated!
VDC at P201:
LED- *: 0.4 @ power on then drops to 0.1 and is stable
LED+ : 200 @ power on then drops to 86.4 and is stable
LED- : 41 @ power on then drops to 7.8 and is stable
LED+ : 125.6 @ power on then drops to 86.4 and is stable
LED+ : Drops to 30 pretty quickly and slowly drops to zero within 1 min
LED+ : Drops to 30 pretty quickly and slowly drops to zero within 1 minComment
"LED- *: 0.4 @ power on then drops to 0.1 and is stable" You have open connection/LED/connector in that string that is why the Cathode return shows 0V.Never stop learning
Replaced main/led driver board and led back lights. Back light flashes on then stays off
VDC at P201:
3.1 - DRV-ON = BL-ON
3 - PDIM1 = PWM Dimming 1
3 - PDIM2 = PWM Dimming 2
LED- *: 0 @ power on
LED+ : 200 @ power on then drops to 88 and is stable
LED- : 27 @ power on then drops to 0 and is stable
LED+ : 125.6 @ power on then drops to 88 and is stable
You still have a bad backlight or a bad connection to them. Always test your backlight before reassembling. The TV will turn on with the panel disconnected. Video record the flash and step through it frame by frame to find the bad strip or string if you don't have a LED tester.Comment
Maybe I can shed some additional light here:
I replaced a whole set of LED's and they would not turn on. I checked the ps output voltages and they agreed with the above post. Except the cathode return voltage was zero. I tested the backlight assembly with a separate tester, worked just fine. Yet when connected to the tv, the cathode (-) return was zero.
I found the reason for this was the replacement diodes were 6 volts each. The originals measured 3 volts each. Correct part numbers but fake parts? Mistake at the factory?
I repaired and reinstalled the original 3volt diode strips and it works fine.Comment
I repaired and reinstalled the original 3volt diode strips and it works fine.I assume no responsibility for any stupid suggestions I might post.Comment
The 55 inch LA and LN series uses the thick LEDs same as LB LF series. I have only encountered 6V LEDs on LG 32 inch LB series. All the new strips on aliexpress and eBay are substitute strips since these models are from around 2013.Last edited by neilc6; 03-04-2022, 11:20 AM.Comment
Do you mean that strips from Ali & eBay are not 3v? Or…?
Please clarify.
Thanks.Last edited by jojo88; 03-29-2023, 05:39 PM.Comment
by StephenHello, got a weird MacBook Air here
board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works... -
by CornitoHello Team,
I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result.... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... -
by CornitoHello team,
I'm back with another topic.
It's a 65C715 TCL tv with backlight issue.
But the problem is a bit strange.
When I took this tv from the marketplace backlight didn't work but picture was ok.
Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
Putting all back together the tv worked fine for weeks. => Contact issue??
Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working.... -
by RiananyainaHello Everyone ,
today I'm coming to you regarding my issue which is no Backlight .
I have image on my screen but no light .
The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
Please find below few informations which can help for the analysis... - Loading...
