IQ SMART TV 22" weird problem
  • rippergr
    replied
    Re: IQ SMART TV 22" weird problem
    The TV is led not lcd so it has no backlight
  • rippergr
    replied
    Originally posted by budm
    This TV has an always on power supply, the ON/OFF pin that you measured 0V is the Backlight ON/OFF control pin and right now the main board is not sending the ON command to turn on the backlights.
    OK. So I must put a resistor 470 to 1K on the ON/OFF pin?
    replied
  • rippergr
    replied
    Originally posted by attainteddragon
    have you jumped the ps on with a resistor to (470 to 1k) see if the backlights and ps are all working properly? disconnect main for this.
    I didn't understand what should I do with a resistor. Can you give me a little more details.
  • attainteddragon
    replied
    capacitance will only give you half the answers as to if the caps are good or not.
    you can download an esr chart easy enough.
  • rippergr
    replied
    I don't have esr meter. Can I check it whith some other way? I have a meter that you put different componenet and tells you what it is (resistor,capacitor, diode etc) which measures the capacitors but I don't now if the values are good (I only understand uF , it gives me some readings like esr but I dont know the "good"values)
    I had changed 3-4 capacitors but I didn't see any change in the behaviour.
    When the TV came it has the thermal fuse blewed and I changed that.
  • attainteddragon
    replied
    the 3.3v regulator is good. looks like the others get their voltage when the ps comes up.
    if you have an esr meter, i would check all of the caps on the main board.
    if they are ok, you might be looking at an eprom failure.
  • rippergr
    replied
    Originally posted by rippergr
    all of them are 1117 B 33 632K
    and all of them have 0v on all pins except the top one which has 3.3V on midle pin and 5V on right pin and 0V on left pin
    edit: The top regulator has the voltages not the top one pin
  • rippergr
    replied
  • attainteddragon
    replied
    these are your voltage regulators.
    i cant make out what the output voltage should be from the pics.
    measure them from left to right. center pin is the same as the tab pin.
    list what is written on the top line of each ic.
  • rippergr
    replied
    What do you mean regulators? you mean transistors?
  • dskall
    replied
    Your not getting any change on on/off pin? Need to check voltages on main at regulators
  • rippergr
    replied
    If I unplug the logic board I cannot power on the TV, it has no lights.
    The voltages on the pins are on 12V rails 12.05V and in all other 0V
  • dick_barton
    replied
    With the main board disconnected what voltages do you have on pins 1-6 when you switch on?
  • rippergr
    replied
    Anyone has any idea what to look/change?
  • rippergr
    replied
    Ok the pins are
    Descr. Standby Volt Power On Voltage
    1)+12V 12.05 12.05
    2)+12V 12.05 12.05
    3)on/off 0.03 0.03
    4)ADJ 5.03 5.03
    5)GND
    6)GND
    I hope the pictures are clear
  • dskall
    replied
    Need good clear straight on pictures of back of tv with cover off and each board.
    Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
    Format:
    Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
    1 - XXXXXXX - XXv - XXXv
    2 - XXXXXXX - XXXv - XXXv
    3 - XXXXXXX - XXXv - XXXv
    4 - etc.
  • rippergr
    replied
    Originally posted by dskall
    I would carefully inspect board for bad connections. Heat or cool board to see if it will turn on.
    I resolder most of the components . I cool the board and I heat it but it still does the same.
    Is there any change that it's problem from the thermal fuse (I changed it because it was burned) or the yellow square capacitor?
  • dskall
    replied
  • rippergr
    replied
    Might pull con1 and see if any arcing in connector or bad solder joints
    That was a good idea. I removed the con1 and solder a cable directly on board but still the same noise and cannot power on the TV altough it has the standby led when I push the on button nothing happens or just shut down the led.
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • huj3r
    Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
    by huj3r
    Hi there!
    I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
    Photo of the situation after the black shadow dissipates:
    After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
    I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
    > This indicates HFR Communication error. [ HFR Communication...
    08-15-2023, 10:55 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • lostone
    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
    by lostone
    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
    05-19-2024, 11:40 AM
