I've picked up a faulty 65" VT20 on the weekend.
The TV doesnt turn on and emits the 10 blink code when connected.
I've opened this TV up and had a look for anything obvious. There is nothing visually obvious to see.
On initial connection I after its first attempt at powering up I've noticed a noise coming from a section of the powersupply. It seems to be coming from one of the transformers. Its kind of a buzzing noise. I've measured standby voltage of 5v and confirmed that is coming through ok to the A board.
Using the switch on the A board you hear the relays kick in and the buzzing noise at the transformer changes to a higher pitch. I can confirm that the 15V is output on the pins on the PSU. I havent checked what happens to it when it gets to the A board as it is only visible on the meter for about 2-3 seconds.
The leds on the SS and SC boards come on while this happens and then gradually discharge when the startup attempt fails.
Another test I've tried was removing all PSU connections to boards other than the A board. I've taken off the D board connectors from the A board too. The same thing occurs at attempted power up and the same 10 blink code is displayed.
So from this I'd assume that the problem is either the A board or the PSU. The only reason I'd guess the PSU is the noises that it emits from the transformer or components near the transformer sound a bit suspect to me.
Any guidance from anyone on what to check?
I've attempted to record the sounds heard when using the power button on the A board to turn the TV off/on.
https://drive.google.com/open?id=0B-...zliMFgydmF1Wms
