LC-40E67UN SHARP No Picture
  • 1beertap
    • Mar 2009
    • 219
    Hey Guys,
    I have a this tv which will power on and display a backlight but with no picture. On the main board, there is a small red LED that blinks. I am thinking that it could be either a bad main board or T-Con. Any ideas? Attached are the photos.
    Thanks.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LC-40E67UN SHARP No Picture
    Check power to your t-con 12v coming in and various other voltages on t-con you can check.
    • 1beertap
      • Mar 2009
      • 219
      On the t-con, I tested 12.13v and fuse is good.
      • 1beertap
        • Mar 2009
        • 219
        After trying to connect a source to the correct input, I'm able to get sound from the tv. Now, I'm wondering if it is the t-con or panel?
        • dskall
          • Oct 2016
          • 2905
          • usa
          There are a number of different voltages on the t-con that could be checked.
          • 1beertap
            • Mar 2009
            • 219
            Could you please enlighten me to the locations and the possible values of such said voltages? I know of the 12v coming from the power supply.
            • 1beertap
              • Mar 2009
              • 219
              I have looked at the LVDS data lines and I see a pattern on the oscilloscope. Whether or not it's a good pattern, who knows but I also see that the lines are inverted pairs (meaning positive and negative). At this point I truly believe I have a bad t-con. I'm hoping the panel is not shorted in some way. I really would hate to put money into a good t-con to just die. Any thoughts? Thanks.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Probably a good mainboard if your getting signals on lvds. A lot of test points on t-con but don't see much identification for them. There are a couple of regulators and coils you can test for voltage.
                  What do you see on the screen if you have the cable between the T-CON and the LCD panel connected one at a time?
                  • 1beertap
                    • Mar 2009
                    • 219
                    budm,
                    After unplugging one cable then vice versa, I am able to get both halves of the screen to come up with slightly different shades but for less than half a second after tv is first turned on. When I turn the tv off and back on again, in order to repeat, There is no difference between either side.
                      https://www.badcaps.net/forum/attach...7&d=1489107014
                      That large SMD IC30 to the right is made to generate 4 Voltages for the LCD panel.
                      I cannot read the P/N of that IC then we may be able to see what is going on in that section.
                      Too bad that they did not have any markings for the Voltage test points.
                      • 1beertap
                        • Mar 2009
                        • 219
                        budm,
                        The part number for IC301 is THV3056.
                          THV3056 spec sheet, then need to trace out the board to see if those Voltages are present or not. Or you can take a chance on new T-CON board.
                          • ygorsan
                            by ygorsan
                            🧩 Problem Summary:
                            • I
                            07-28-2025, 08:34 AM
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
                          • maxim2511
                            LG 55EC930V OLED - swich on swich of no screen
                            by maxim2511
                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                            Then I get an idea to take it apart and clean boards from dust.
                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                            05-14-2021, 02:21 AM
