Sanyo DP50749 Plasma Powers on, no video, then powers off, repeats
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    I'm working on this incredibly smelly Sanyo Plasma and am trying to find out why it isn't working quite right. What happens right now is the power indicator will light up, the set will turn on, the screen will light up, and then the screen will power off after a couple seconds (nothing ever shows up on the screen) before it clicks off. Afterwards, it'll start the process again and try indefinitely to get fully powered up, even though it never gets there.
    In the time that the panel does spend powered on, Vs and Va look good.
    Any ideas as to where to start on this one?
  • maxvalutech
    • 804
    • australia
    Re: Sanyo DP50749 Plasma Powers on, no video, then powers off, repeats
    From your pics looks as if y and x (left and right from rear) have individual connections from power board so disconnect first one and if no joy with vs staying on then disconnect the other. Not sure how protection circuit works on this set. Main board seems ok in basic operation. Why the smell ? what and where followed by why.
    • R_J
      • 9588
      heavy smoker. It is posible the caps are bad in the power supply even though they are not bulged, If they are bad the power supply just can't maintain the voltage.
      I just repaired a vizio power supply and the caps on the +5 looked just fine, even the voltage measured 5 volts but as soon as the tv was turend on it would shut down again
      it had 2 1000uf/10v completely open
      • SurrealMustard
        • Jan 2015
        • 487
        Foggy, smokey
        Same results with either one disconnected.
        Tobacco; everywhere; owner must have smoked around it a lot.
        That sounds reasonable. Are they wired in parallel or can I test them using my capacitor tester without having to desolder?
        • maxvalutech
          • 804
          • australia
          Yes it looks like it was in the middle of the tip for a year. Samsung boards? Suggest read Samsung Tech Talk vol 4 no 11. (Google it up) testing methods changed 2010. Of course you have cleaned everything up including connectors etc etc.
          • microvibe
            • Mar 2013
            • 275
            • canada
            Just repaired one of these. Disconnect main board . Behind main is controller board there is 4 pins in jumper block. Short all 4 I just used screw in middle . Jumper pws-on the psu and plug in. Will show test pattern if the rest of boards are good.
            My tv it was ic1630 which is right by big silver box on main board. Pin 2 didn't have 5v.
            • SurrealMustard
              • Jan 2015
              • 487
              Thanks for the tip!
              Right on! After doing that, the panel immediately came to life displaying the test patterns. Looks like it'll be time to find a mainboard for this thing.
              • SurrealMustard
                • Jan 2015
                • 487
                Fixed!
                Mainboard replacement fixed it!
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  FYI I just got one of these. The problem on the main board is corrupt IC 5750A flash nand under shield. Available on ebay
                  • SurrealMustard
                    • Jan 2015
                    • 487
                    Aftermath; epilogue
                    Good to know. Any ideas as to why they fail so often?
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Don't know this one took eight years.
                      • SurrealMustard
                        • Jan 2015
                        • 487
                        That'd be my guess
                        That'd be my guess unless somebody fixed the same problem in between then and now.
                        • KYBOSH
                          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                          by KYBOSH
                          Saved this beast from the landfill this weekend.
                          Manfactured July 2013 in Mexico.
                          I love working on plasma TVs.
                          Its been a while but I was lucky enough to find 2 this week.
                          The TV powers on and stays on but no picture. Havent checked for sound yet.
                          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                          Will start troubleshooting tonight.
                          10-17-2024, 01:17 PM
                        • zlr8r
                          Asus ROG Strix Gaming x99 mobo - powers on , then off - repeats
                          by zlr8r
                          Hey all, my first post here ..yay...!
                          so , lets kick off with the problem I have with this mobo.
                          -= Asus ROG Strix Gaming x99 =-
                          Background info - bought 2 different boards from eBay to try and fix, one i think i can fix, the other ... not so much (which is why im here).
                          There is no obvious damage or signs of previous tampering. in fact, i could swear the board is brand new, its that clean...
                          Motherboard symptoms:
                          (with no peripherals attached).
                          Motherboard does light up and looks to be functional (but isn't)....
                          02-13-2023, 05:22 PM
                        • canadaboy25
                          Sanyo DP5749 Plasma won't power up
                          by canadaboy25
                          Hey everyone,
                          I was given a Sanyo DP5749 Plasma that has failed. The symptom is the TV tries to start up and shuts back off about 3 seconds later. With the service manual I was able to determine that the TV is shutting down due to detecting a missing power rail. The 5V supply to the logic board is okay at startup but after a second it disappears. The TV shuts off shortly afterwards.
                          I traced the problem to a 3.3V enable signal from the D board to the power supply. This signal disappears for some reason which shuts a few power rails on the PSU off. The signal comes...
                          02-01-2021, 01:19 PM
                        • canadaboy25
                          Hitachi 55HDX99 Plasma Powers on but no picture
                          by canadaboy25
                          Hey guys, I recently acquired a Hitachi 55HDX99 plasma TV that doesn't work. The TV powers on and eventually goes into standby which is indicated by the blue power led changing to orange. If I plug a VCR into it to keep it awake, I can feed an audio source in and it will play the sound no problem. The volume controls on the TV work as well so it is obviously just a display problem.
                          I found the Hitachi service manual online which is also hosted on tom66's manual archive. Compared to the Panasonic service manual I had for the last plasma I worked on, this one is underwhelming to say...
                          03-22-2019, 12:06 AM
                        • malogro
                          Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                          by malogro
                          Hello all,
                          I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                          Intro:
                          This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                          Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                          04-14-2023, 04:44 PM
