Sanyo DP5749 Plasma won't power up
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey everyone,
    I was given a Sanyo DP5749 Plasma that has failed. The symptom is the TV tries to start up and shuts back off about 3 seconds later. With the service manual I was able to determine that the TV is shutting down due to detecting a missing power rail. The 5V supply to the logic board is okay at startup but after a second it disappears. The TV shuts off shortly afterwards.
    I traced the problem to a 3.3V enable signal from the D board to the power supply. This signal disappears for some reason which shuts a few power rails on the PSU off. The signal comes from a custom Panasonic chip on the D board so I am unable to trace it further than that.
    According to other threads on here about this model, it appears a common problem with this TV is a NAND flash chip on the main board getting corrupted. The service manual also verifies that this is a known problem. However, the symptom that is listed is power cycling of the TV with a 15 second or so delay. This is not the symptom I have as the TV shuts down after 3 seconds and does not try powering up again until you push the power button.
    Before I pay some guy on eBay $40 for a flash chip which hopefully has the correct firmware on it, I would like to be sure this is in fact the problem.
    Does anyone have any input?
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Re: Sanyo DP5749 Plasma won't power up
    Anyone?
    canadaboy25
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • brav1ez
      ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
      by brav1ez
      I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
      I’ve tried:
      - CMOS reset
      - Removing the SSD/HDD
      - Reseating RAM (removing each stick individually stops boot completely)
      - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
      With...
      09-07-2025, 10:47 AM
    • Cooperr
      Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
      by Cooperr
      I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
      The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
      10-21-2025, 01:11 PM
