RCA 46LA45RQ no backlight
  • Jim1590
    • Jul 2013
    • 98
    Greetings all again. Craigslist freebie here. No back light after a minute or two when powered on. Flashlight test shows that the image is still on the screen.
    Opened it up and got 23-24 volts on all 5 pins going from power board to the backlight inverter board. When the backlight cut out, no change in the readings.
    Right now I am thinking a bad cap somewhere on the backlight board. There are 8 caps at 35v 390uf. Since the TV is 7 years old, I might as well replace all 8.
    Now I have a bag of 35v 470uf caps from a prev repair. Was just as cheap to buy the 50 count bag as the 4 I needed. Brand is Chenxing off of Amazon.
    Can I use the caps on hand? Or should I just buy the 390uf ones?
    Next post with have pics of the boards.
  • Jim1590
    • Jul 2013
    • 98
    Re: RCA 46LA45RQ no backlight
    First set
    • Jim1590
      • Jul 2013
      • 98
      Second set
      • Jim1590
        • Jul 2013
        • 98
        Anyone?
        • finntricky
          • Jan 2014
          • 449
          take the inverter out and check the back for burn marks/discolouring, that will give an idea as to where there may be a problem,
          • Jim1590
            • Jul 2013
            • 98
            Nothing on the back. Looks like there is no tracings or components at all. On the front, most of the solder points have at least some Browning.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Check those 2 fuses on the Inv Bd. Ckeck if there is voltage on both sides of each fuse.
              • Jim1590
                • Jul 2013
                • 98
                Not at home to test right now, but wouldn't a bad fuse be bad all the time? The backlight works for a few min and incidently it works much longer if I have the back cover off. Discovered that when I was testing. That's why I thought heat related cap issues.
                • DOPPLERBOB
                  • Nov 2012
                  • 12
                  • usa
                  Try using a heat gun and freeze spray to see if you can narrow down the heat related problem area. (providing you have a heat gun and freeze spray of course). You can substitute the heat gun with a hair dryer but it doesn't direct the heat into a small area as good. But it does heat up areas quicker and you then can use the freeze spray to isolate the problem.
                  • CapLeaker
                    Leaking Member
                    • 7980
                    Since the back lights come on for the first minute or two and then go out, I rule out capacitors. My bet is on a bad transformer or a bad bulb, some component that draws more current when getting hot.
                    Compare the resistance of the secondary output winding of each transformer on the inverter board. The tolerance can not exceed 3% of each other.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      My bad....Some how missed the came on and shut off part.....NO not fuses...but CapLeaker set you in the right direction...Thanks
                      • triplefour
                        by triplefour
                        09-13-2023, 10:43 PM
                      • DanPoka
                        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                        by DanPoka
                        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                        02-15-2025, 05:05 AM
                      • Comp_Pro
                        No Backlight Macbook A1990 820-01041
                        by Comp_Pro
                        Hello all,
                        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                        Tests performed:
                        There is no backlight even with a good screen.
                        Backlight IC is receiving the correct support voltages.
                        Fuse F8400 ok
                        Current sense resistor R8400 ok
                        Backlight IC is receiving 3.3V on enable pin.
                        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                        Backlight IC receiving 5V from PP5V_G3S
                        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                        05-06-2024, 10:23 PM
                      • cheebster
                        iPad Pro 12.9 5th Gen Backlight Issue
                        by cheebster
                        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                        Anyone...
                        05-20-2025, 09:17 AM
                      • canadaboy25
                        LG Flatron 24EN33TA No Backlight When Cold
                        by canadaboy25
                        I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                        I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                        03-07-2023, 12:23 AM
