SONY KDL60-NX801 Panel
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Does this look like a panel issue? Originally, this set had only thin green and white vertical lines on display. Replaced T-Con with a new one from China.
    Attached pictures are the result. Could possibly reseating one of the ribbon cables fix this?
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: SONY KDL60-NX801 Panel
    Anybody? Any input would be appreciated.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Looks like a connection issue to me. I'd start with reseating the ribbons. Make sure none of the traces on the ends are damaged / bent.
      If this is anything like the 46" version of this series that I've worked on, the t-con ribbons are an absolute PIA.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Indeed they are. There are four of them. Do they correspond with the opposite zones on the screen or is the far left ribbon from the back the far right side of the screen looking from the front? If I only need to reseat one, I would rather do that than doing them all.
        • dskall
          • Oct 2016
          • 2905
          • usa
          I would try resetting them at the t-con since you now have new issue after t-con replace.
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Yes, my question is how the ribbons equate to screen sections..I only have an issue with one ribbon..why reseat all four?
            • aaronwt6
              • Apr 2013
              • 855
              • US
              It should be the ribbon that corresponds to that screen section.
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                Going to check it out now..Thanks!
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  It was, indeed, a ribbon alignment issue. Working like a champ.
                  Thanks to All!
                  LJ
                  • aprasad
                    • 11
                    hi
                    I have a kdl60w850b with screen issue , one side puts mt tv to 5 blinks alarm , using just one side ribbons from t con works fine but only half screen , anyone has any options ?
                    I might need new screen sine i swapped the ribbons from tcon from left to right and problem didn't follow and stayed issue with one side , also tried new tcon board and all voltage in good specs .
                    thanks
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      I would say you have problem with panel pcb board on the affected side
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Sharp LCD panel... Snap a picture of the good side working and let us see what it looks like.
                        • aprasad
                          • 11
                          thanks DSKLL
                          what is pcb board and where does it normally is located /
                          thanks
                          • aprasad
                            • 11
                            right side half is good as it can be no issue but when i connect left side ribbon to tcon its outs me in 5 blinks ,i pulled apart the tv right now so i cant take any pictures
                            • aprasad
                              • 11
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                My guess is the right side gate drivers on the right hand (side of the panel not bottom) failed.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Can you take pictures of the side panel drivers on the failed side?
                                  • aprasad
                                    • 11
                                    whats side penal drivers ?
                                    • aprasad
                                      • 11
                                      there is nothing connected from sides , only 2 ribbon from bottom to each side
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        the side drivers aren't on boards, they are in the bonded ribbons on the side of the panel... look close.... that's what you need to provided pictures of.
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • rimwall
                                          Sony KD-65x8500b - bad Tcon or panel?
                                          by rimwall
                                          Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                                          a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                                          b) the Tcon board is malfunctioning,...
                                          10-24-2023, 07:58 PM
                                        • swrb898
                                          Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                          by swrb898
                                          What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                          Problem:
                                          Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                          My troubleshooting got me this far:
                                          With the left-hand TCON to bottom-board ribbon cable...
                                          12-28-2021, 08:12 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
