Sharp Aquos LC-60LE600U no power period
  • tjmethod
    • Jun 2013
    • 137
    Hello starting a new thread since I had the wrong model on the last one. It is a Sharp Aquos LC-60LE600U not the LC -70LE640U. Anyway, the set has no power period unplugging, holding power down for 10 sec the plugging back in /vol+channel down while plugging in did nothing,. I did pull the power supply and checked the fuse with a dmm which zero'd out buzzed. And will have to find what all the pins should read from the socket that connects to the main board. If anyone else might have any suggestions or what else to check that would be appreciated...
  • mmartell
    • Oct 2013
    • 3189
    Re: Sharp Aquos LC-60LE600U no power period
    No flashing light sequence on the front bezel ?
    • tjmethod
      • Jun 2013
      • 137
      Hi yes there is no lights at all as if it isn't plugged in
      • tjmethod
        • Jun 2013
        • 137
        With the advice of 'dskall', I did back probe the main board plug- plugged in to the power supply and power to the board. I have a picture and illustration of the voltages I found. I have no schematic or diagram or know where to find one. Any input with what I found would be a big help-
        • dskall
          • Oct 2016
          • 2905
          • usa
          The connector PD and the numbers around it tell you what voltages you should have on the pins eg PD-5-6-7-8 should have 13.2vdc when things are working. Next to connector should tell you were pin 1 and 24 are on connector. Take readings and post as p5 13.2v = voltage you get for all pins. Then push power button while probing Pin 14 ps-on and you should get a voltage.
          • tjmethod
            • Jun 2013
            • 137
            Hi thanks I am just confused as to what slots correspond to what numbers but I did go back and back probed each one again while hitting the power button and didn't see any change. I did accidentally leave out a reading before which was 0.00 that I don't see matters. Do you know where I can locate a diagram
              If you look at the PD connector on the top side of the board you will see '1', and '2' printed right next to the connector.
              The exposed pin you can see on the top side of the board are the ODD number pins, the other pins you cannot see are the even number pins, which you can probe them on the female back side of the connector.
              We need the pin name and follow by the DCV reading of each pin so we can see which Voltages and signals are missing.
              http://www.shopjimmy.com/sharp-runtk...-led-board.htm
              Sharp RUNTKB057WJQZ (DPS-168JP A) Power Supply / LED Board
              Pictures provided by shopjimmy.
              • R_J
                • 9561
                I don't know exactly which board you have but Sharp did have a problem with D7805 shorting. might be worth checking. original diode is NUR460, change to MUR460
                • tjmethod
                  • Jun 2013
                  • 137
                  Ok so I think I know what pin and its number - when I tested with the dmm with power to the board and compare to what printed around the, they don't add up. I had back probed but the readings didnt change but I will need to run through it again tomorrow. Any other suggestions?
                  any luck on the 757?
                  • tjmethod
                    • Jun 2013
                    • 137
                    Hi thanks I saw the D7805 diode but I did check it and all the ones on the board in diode mode but without removing them from the board. Between all of them there was a range from 300's to 600's with the pos side on the anode side and neg on the cathode side and reversing the probes gave me an l or 1 left on the screen. Does that sound like it may be ok?
                    • mmartell
                      • Oct 2013
                      • 3189
                      The readings aren't supposed to change but you're supposed to LABEL each pin so we know what they SHOULD be.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        The readings make no since to me. Look on other posts to see how to format your voltages. Should be
                        p1 pson =?v
                        p2 gnd =0v
                        p3 stby5v =?v format
                          https://www.badcaps.net/forum/attach...2&d=1485933978
                          You count the pin wrong, I guess you did not read my post 7 about the pin '1', '2' and the reporting format.
                          I do not have the board in front of me so I did the research to find the pictures of the board and study them and give the instruction on how the pins are assign.
                          What more do I have to do?
                          • tjmethod
                            • Jun 2013
                            • 137
                            With Magnavisors on I didn't even see that 1 & 2 tucked in there- in post 7 I thought you were making reference to (PD-1-2) PNL12V since it was at the top of the PD. Anyway, I hope this makes better sense. Also while I back probed all the pins, I tried hitting the power button which did nothing-
                            Pin 1 PNL12V = 0.00V
                            Pin 2 PNL12V = 0.00V
                            Pin 3 GND = -0.00V
                            Pin 4 GND = -0.00V
                            Pin 5 UR13.2V = 13.15V
                            Pin 6 UR13.2V = 13.15V
                            Pin 7
                            Pin 8
                            Pin 9 GND = -0.00V
                            Pin 10 GND = -0.00V
                            Pin 11
                            Pin 12
                            Pin 13 AC_DET = 3.28V
                            Pin 14 PS_ON = 2.07V
                            Pin 15 BU5V = 5.01V
                            Pin 16 PNL_POW = 0.05V
                            Pin 17 PWM1 = 0.16V
                            Pin 18
                            Pin 19 DIMMER = -0.00V
                            Pin 20
                            Pin 21
                            Pin 22 ERROR = 0.95V
                            Pin 23
                            Pin 24 STB = 0.58V
                              BTW, did you see any blinking error codes at all?
                              For example:
                              https://www.badcaps.net/forum/showth...&highlight=STB
                              Pin 16 PNL_POW = 0.05V = No command to turn on PNL12V for running the T-CON
                              Pin 24 STB (Von) = 0.58V = No BL-ON to turn on backlights circuit
                              No dimming control:
                              Pin 17 PWM1 = 0.16V
                              The key is this one which I do not what it should be for normal operation:
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                budm on post #3 he says there are no lights. Seems like he should be getting blink code.
                                  I expect error codes since the standby power supply is present, other wise it means the main board is dead due to what I do not know.
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    tjmethod says pushing power button does nothing. Maybe problem with power to buttons and led on front? I have quick question for you budm if I might and don't want to hijack tread. You say pfc should be >360v if it is 357v will that cause a problem?
                                    • tjmethod
                                      • Jun 2013
                                      • 137
                                      Hi yes unplugging and holding power, plug in hit power again or vol and chan down while replugging does nothing. when I saw the key controller is plugged into the main board I figured that might be smoked worse then the power supply- is there some method of testing the main?
                                      • tjmethod
                                        • Jun 2013
                                        • 137
                                        Here the main
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
