Sharp 70" LC-70LE734U : No Picture : 2 Slow - 3 Fast
    Re: Sharp 70" LC-70LE734U : No Picture : 2 Slow - 3 Fast
    Thanks!
    One thing that did not make sense on that thread is that he does not get any error blinking codes at all.
    • R_J
      • Jun 2012
      • 9582
      I have this excerpt from my LC60LE632U manual if it helps
      • Inverted
        • Dec 2015
        • 26
        PD
        Pin, Vol, Name
        1. 12.2 : Pnl_12v
        2. 12.2 : Pnl_12v
        3. 0 : Sgnd
        4. 0 : Sgnd
        5. 13.43 : Ur13v
        6. 13.43 : Ur13v
        7. 13.43 : Ur13v
        8. 13.43 : Ur13v
        9. 0 : Sgnd
        10. 0 : Sgnd
        11. 0 : Sgnd
        12. 0 : Sgnd
        13. 3.32 : Ac_det
        14. 2.85 : Ps_on
        15. 5.06 : Bu+5v
        16. 3.27 : Pnl_pow
        17. 0 : Vsync
        18. 3.28 : Scl
        19. 1.98 : Nc
        20. 3.28 : Sda
        21. 0.4 : Ofl
        22. 3.29 : Error
        23. 0 : Nc
        24. 3.25 : Stb
        This is the board that throws the 1-1 error, but that I can get the tv to turn on with by holding vol+ and channel-. If you scroll up to the very first post, you can compare to the board where I cannot get the screen to turn on and it throws the 2-3 error.
        I am confused by pin 19 that shows not connected(there isn't even solder on it on the backside, but it still has a voltage)?
          Thanks! So the ERROR pin according to service manual, it is for the Backlights error.
          When ERROR is present, it will be low (<1VDC, and when there is no error it will be around 3VDC, I went through many service manuals to find out but no info, so thanks to you now I know what it should be.
          Now back to that thread.
          • Inverted
            • Dec 2015
            • 26
            Do you think it would cause any harm if I jumper error to ac_det on the main board I have that isn't working? Do I need to use a resistor or can I just use a piece of wire?
            • mmartell
              • Oct 2013
              • 3189
              Originally posted by Inverted
              So I just tried menu 2489. What am I supposed to see happen? I hit menu on the remote and it obviously brings up the tv menu, then when I hit 2, it starts acting like I am entering a channel to go to, once I enter 2489 and then wait about 2 seconds it just goes back to displaying the current channel number that it is on.
              It's supposed to bring up another menu with four options - obviously doesn't work on your set.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #27
                its odd you cant get into the service menu at all i wonder if a faulty mainboard could stop you getting into it?
                • Inverted
                  • Dec 2015
                  • 26
                  I may have come up with a new mainboard locally to try. If it throws the 1-1 error can I be fairly certain that it is an issue with my backlighting at that point?
                  • Inverted
                    • Dec 2015
                    • 26
                    Came up with another FM24S board to try. I immediately tried to go into service mode the first time I powered it on since someone has said that if it throws the 1-1 error 5 times the board is toast? Anyways, same thing happened, it had the solid light for eight seconds and then threw the 1-1 error again. So I guess I need to either take a look at the back lighting or just use vol+ and channel- to override the error and use the tv that way...
                    • tjmethod
                      • Jun 2013
                      • 137
                      Bud my 19th pin on the PD is soldered, anyway but since there's no response from the key control board showing any error codes, I checked the RA where the key control board plugs in to the main and these were the voltage readings I got, there were no voltage around it printed on the board that I could see. Of course the last four oins are the key board controller.
                      Pin 1. - 0.00V
                      Pin 2. - 0.00V
                      Pin 3. - 0.00V
                      Pin 4. - 3.25V
                      Pin 5. - 3.20V
                      Pin 6. - 0.74V
                      Pin 7. - 0.00V
                      Pin 8. - 0.00V
                      Pin 9. - 0.00V
                      Pin 10. - 0.00V
                      Pin 11. - 0.00V
                      Pin 12. - 0.00V
                      Pin 13. - 3.25V
                      Pin 14. - 3.15V
                      Pin 15. - 3.15V
                      If these voltages are correct then this would point towards the key control board may have failed since we cant get blinking error codes?
                      • Caio Fabio Souza
                        • Sep 2024
                        • Brasil
                        #31
                        Boa tarde, alguém pode me informar a descrição do integrado, que está presente na posição IC7905 na Placa Fonte.
                        Att
                        • tamr
                          iam looking for bios dump for i-Life ZED NOTE II S Part No: IL.1303.232.BIAES
                          by tamr
                          I am looking for a BIOS dump insert for i-Life ZED NOTE II S Part No: IL.1303.232.BIAES Board designation: INET J313Z-REV10 and iJ313ZA1-V20
                          PCBA: IJ313Z41S2BF0EF00001001
                          the board has an Intel SR2KT - Atom X5-Z8350 processor
                          and eMMC memory: BWCTGSC21G32
                          G Bone BIOS: 25LQ64CVIG...
                          06-02-2024, 07:52 AM
                        • levitor
                          4.0.15.1303 txe
                          by levitor
                          Hello guys need help to clean TXE
                          It late display....
                          09-14-2022, 08:34 AM
                        • jinu_j
                          Boston Acoustics Soudware Subwoofer PowerSupply
                          by jinu_j
                          Hi Folks
                          I am looking for help to trouble shoot my Boston Acoustics Soundware X subwoofer power PCB. The Circuit diagram is attached. I have checked the voltage across C3 (there is no capacitor as this is 240V board). The voltage i get is about 318V so i am assuming that the circuit behind that is working properly. But now I am not sure how to proceed. The circuit on the Left-hand side of the circuit is on a separate PCB that's soldered onto the board using the connector CN4 shown in the circuit diagram. So its difficult to trouble shoot components on that.
                          There...
                          08-20-2023, 02:08 AM
                        • FlorianP
                          Sharp Aquos LC-40LE810E - 2 long, 1 short
                          by FlorianP
                          First of all I am not native English speaking, so sorry for potential mistakes or misunderstanding.
                          I have a basic multimeter and a soldering iron. No electronic pieces for replacement for the moment, but I can buy some.
                          I have a Sharp Aquos LC-40LE810E with issue.
                          When I turn on my TV with the remote control, I have 2 long flashing on the boomerang symbol, and no image/no sound.
                          I saw in the service manual that I need to click on « menu » button of the remote control to have more information.
                          --> Error core...
                          09-05-2020, 10:02 AM
                        • Anzio
                          Sharp LC60E79u 2 blinks power/3 Blinks OPC
                          by Anzio
                          I have a Sharp LC-60E79U with the blinking light error (Power and OPC blink 2 times together then OPC blinks 1 time. I read the previous thread on Sharp lc60e79u (https://www.badcaps.net/forum/showth...t=66913&page=3) with this same issue, but no resolution was posted.
                          The service manual indicates this as a “DET_5V (33pin) error (L). 5V is not applied.”
                          I cannot enter service mode by pressing input and channel down and plugging the unit in to power outlet. However, I can override and enter the diagnostic mode if press channel down and volume up and...
                          07-03-2020, 01:12 PM
