Eeprom dump thread!
This is a sticky topic.
Attached FilesLeave a comment:
Try programming two chips at once with this set, just save your original dumps.Attached FilesLast edited by lotas; 12-16-2024, 07:24 AM.Leave a comment:
I'm not sure I know exactly what the data you mention are but on the plate I can see the following information:
- LD.M3553.A
On the panel is the following code:
- 15Y_L48GF11BMB7S4LV0.6
and I have no information about the processor or possible damaged firmware
Hello everyone, I appreciate you allowing me to interact with this great community. I come to you to request the necessary firmware for a VIOS TV4817 screen, so far I have seen that they published it for version 4814 but it seems to me that they are not compatible, the memory of my screen is a HX1717 25Q32CSIG flash memory AP0Q138 I would appreciate your help to carry out this work☺Leave a comment:
Hello guys,
I need a dump for a Samsung TV stuck in boot loop.
Model : UE40EH6030WXZF
Winbond 25q40bv
Big thanks.
Samsung Model Code: UN40MU6300FXZA
Version No: FA01
Hi all I am looking for a dump for a ves550undl -2d -n11 panel.The original board is 17MB211 but it is dead now I have two options to put 17MB82 or 17MB140 (I don't have 211) Both boards need software as the colors are polarized and the picture is inverted .I prefer to put 140 which is from 48 inch TV with panel ves4800unds -2d -n12. I modified the dump with vestel panel editor, but the picture is purple and there is no red color. Apparently it wants an exact dump I will be glad for your helpLeave a comment:
Here is a working dump of eMMC (Samsung) on Sony KD-55XG8596 1-983-791-12.
https://drive.google.com/file/d/18X5...nclLW870i/viewLeave a comment:
where you see the first topic watch a little up the "New Topic +" button.. bye..Leave a comment:
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... - Loading...
