Post your original, non-working dump here, I'll take a look and see if I can fix it for you.
Have you been looking for this dump for 5 years?
https://www.badcaps.net/forum/troubl...53#post1325853
Eeprom dump thread!
This is a sticky topic.
I really appreciate if any member could share a dump for a TV LED Blaupunkt 39/401l, or some other brand that uses the same mainboard/panel combo, the tv is stuck in standby
Modelo Nr: 39/401L-GB-5B-1HUHBKUP-EU
Modelo Ref: B39A401TCUHD
Mainboard: T.MSD309.BTU87
Panel: v390DK1-LS1
Thanks in advanceLeave a comment:
Hi, anyone got panel firmware
17Mb110
VES500UNDC-2D-N12
Thanks In advanceLeave a comment:
Hello, good vibes for everyone, I need a dump of a Toshiba 37AV52R TV, card number STA40T VTV-L4008 REV:1
from 2008/12/18.
If anyone can help me, I'd appreciate it, the LCD is old but still works.Leave a comment:
hello,
I have samsung tv UA65NU7300g no power, no standby light but if i remove the connector of motherboard the backlight is working and 12.8 volts is present. need help for dump file of IC1604 25q40cl.
i have backup of the original file. can please check my dump if its ok. Thank you.
Hello.. Master lotas.. need your help. thank youLeave a comment:
Thank you! The TV is always on standby mode and there's no picture or sound. Unfortunately we haven't purchased the device yet that does that (dump or program an eeprom) nor a spare similar device to cross check. We already checked the board and suspected its the chip labeled as V502 on the board. This is our first time to handle this challenge. Thanks in advance
Hello everyone , hope y'all doing great ,
i'm looking for dump eeprom for Samsung UE32J5570S , Main board : BN41-02353B , thank u very much much appreciatedLeave a comment:
Thank you! The TV is always on standby mode and there's no picture or sound. Unfortunately we haven't purchased the device yet that does that (dump or program an eeprom) nor a spare similar device to cross check. We already checked the board and suspected its the chip labeled as V502 on the board. This is our first time to handle this challenge. Thanks in advanceLeave a comment:
What is the problem with the TV, post your original dump here, if it is not working, I will try to restore it for you.Leave a comment:
thank you.. master lotas for checking my dump... now i know that my dump is good. the problem maybe somewhere in motherboard.Leave a comment:
hello,
I don't see a problem with your dump, it's working.Last edited by lotas; 07-23-2024, 02:42 AM.Leave a comment:
hello,
Hello.. Master lotas.. need your help. thank youAttached FilesLeave a comment:
Yes was not working, "power-up, logo and reset" .
Finally loaded the firmware for one "ok odl 32631H-SB EL" from post https://www.badcaps.net/forum/troubl...64#post1683821 , worked only remote control is diferent and used one universal one.
ThanksLeave a comment:
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... -
by jimhaHi ,
I'm looking for a dump to repair my screen
Thanks-
12-09-2024, 03:52 PM -
- Loading...
