Eeprom dump thread!
This is a sticky topic.
  • crazycavan
    • Sep 2022
    • 16
    • paris
    #1881
    thank you very much​
    • Manucsl
      • Feb 2025
      • 5
      • France
      #1882
      Hello.
      My TV is a QE65Q800TATXXC Samsung TV.
      Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
      Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
      Any ideas to check would be very appreciated 😊
      After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump it.
      You can find the dump attached to this message in zip format.
      Can you please check this eeprom ? and may be correct it ?
      Thank you very much for your help.
      Manu
      BN41-02752A MAIN AV BOARD BN41-02752A (BN94-00038G) - SAMSUNG
      BN44-01068A LED DRIVER BOARD
      BN95-06565A T-CON
      BN44-01073A Power board​
      • Manucsl
        • Feb 2025
        • 5
        • France
        #1883
        Nobody ??
        • Willail
          • Jan 2016
          • 29
          • France
          #1884
          Originally posted by lotas
          Re: Eeprom dump thread!
          Токаї ltl-1902e hk-7050-ci-v3.04-b
          Hello Lotas,
          I need the dump for a Hyundai TV. 32inch
          Model 32D9A
          Main TP.S506. PB801
          Panel HKC Electronics HK315LEDM-0H08H AJ32T03
          Thank you for your help.​
          • lotas
            • Jan 2016
            • 4536
            • Russia
            #1885
            Originally posted by Willail
            Hello Lotas,
            Model 32D9A
            Main TP.S506. PB801
            There is a white tag on the bottom bar of the panel and it has the panel number written on it, what is it?
            • juan667134
              • May 2019
              • 28
              • peru
              #1886
              EPROM help me please
              television model; QN55Q70RAG
              motherboard model; BN41-02695A
              IC1502-IC1503-IC801- IC701 EMMC​
              • Willail
                • Jan 2016
                • 29
                • France
                #1887
                Hello Lotas,
                I send you the pictures of the panel number
ID:	3597496 Click image for larger version
ID:	3597502 Click image for larger version
ID:	3597498 Click image for larger version
ID:	3597499 Click image for larger version
ID:	3597500 Click image for larger version
                • lotas
                  • Jan 2016
                  • 4536
                  • Russia
                  #1888
                  Try this one, it's a dump from Akai though, the remote might not fit...
                  • lotas
                    • Jan 2016
                    • 4536
                    • Russia
                    #1889
                    Here's more...
                    • Willail
                      • Jan 2016
                      • 29
                      • France
                      #1890
                      Hello Lotas,
                      Thank you for the dump. I test the Akai dump but it doesn't work.
                      It could possible that the firmware is not the same on board TP.S506.PB801 and TP.S506.PB818.
                      I will test the 2nd file today. If i will send you the dump of my TV, could you fix it?
                      Thank a lot
                      • lotas
                        • Jan 2016
                        • 4536
                        • Russia
                        #1891
                        Hello Lotas,
                        Thank a lot
                        Try this dump, it's smaller in size, don't pay attention, write it down as is.
                        • Willail
                          • Jan 2016
                          • 29
                          • France
                          #1892
                          Hello Lotas,
                          Thank a lot for your file, the TV works again. You are the best !!!
                          • lotas
                            • Jan 2016
                            • 4536
                            • Russia
                            #1893
                            Hello Lotas,
                            OK!
                            • PNI E.
                              • Nov 2024
                              • 96
                              • Italy
                              #1894
                              Hello guys, I need the dump file for a Samsung ue55tu7170u someone can help me thanks, main board bn94 15314t
                              • porfyriadhs
                                • Oct 2023
                                • 70
                                • Greece
                                #1895
                                Hello am looking for firmware for Vestel tv 17mb171 32 inch tv . If anyone please help
                                • yokoono
                                  • Apr 2010
                                  • 479
                                  #1896
                                  1. What is the problem with the TV?
                                  2. What is the TV model?
                                  3. What is the panel code (VES315xxxx-xx-xx)?​
                                  • lotas
                                    • Jan 2016
                                    • 4536
                                    • Russia
                                    #1897
                                    4. Which firmware, firmware via USB or Dump eMMC?
                                    • porfyriadhs
                                      • Oct 2023
                                      • 70
                                      • Greece
                                      #1898
                                      Hello again need firmware via usb because the tv goes to boot loop. It says not enought space and I couldn't make anything. Tv is Toshiba model 32la2063dg/2.
                                        • 20588
                                        Please post pictures that can be read that don`t need rotating..
                                        • porfyriadhs
                                          • Oct 2023
                                          • 70
                                          • Greece
                                          #1900
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
