Eeprom dump thread!
This is a sticky topic.
+ More Options
Posts
  • alhootalhoot
    • Apr 2012
    • 7
    Re: Eeprom dump thread!
    More files
    • Hamie
      • Apr 2014
      • 1383
      Originally posted by turkay06
      please try..
      This is just a copy of the file I uploaded on page one of the thread. It's for a 32" not a 40"
      • alhootalhoot
        • Apr 2012
        • 7
        Thanks for your reply. I'm attaching the file i've read from the SPI flash chip with the fault (no display on screen), hope someone can see or compare it.
        I have tried re-flashing the same file back on the same chip and on another (new) chip, but fault remains. Also tried fitting a chip from a 50" Digihome tv and as expected worked but with some issues like inverted picture and un-steady picture (flickering).
        • beastaS
          • Apr 2018
          • 13
          #124
          Looking for one for Samsung UE55F9000STXXU. Any leads?
          • jones
            • Jan 2012
            • 23
            #125
            looking for, apex LE4643T, mainboard t.ms3391.a3b eeprom file
            thank you
            • 1HandyDud
              • May 2018
              • 5
              Hello forumers and cheers to all!
              I am hoping to find software for LG 42LF11UA TV North American market.
              I believe there's no problem with power board and or T-Con, the problem is either Mstar (IC100) chip or its corrupt software. I was able to de-solder FLASH chip and read it out/scan for bad blocks. If you could kick me in the right direction and/or throw some software for this model, I would be much appreciative of your generous contribution.
              Thanks.
              • 1HandyDud
                • May 2018
                • 5
                On a side note regarding this LG TV set, the main board appears to be dead and there's no indicator lights, however XTAL 12Mhz is alive and I was able to simulate backlight turn on, so inverter is also good. There's a short period of activity at power on (plug inserted into AC outlet) on BIOS EEPROM chip data lines, so maybe it needs re-flashing too. I could post dumps of those chips here for your review.
                Thanks.
                • sordids999
                  • May 2013
                  • 2149
                  • uk
                  #128
                  Has anyone got the firmware for a LOGIK L32HED13A T.MSD309.B81C
                  Backlight working but nothing else remote sensor is working but no display
                  • 1HandyDud
                    • May 2018
                    • 5
                    Thanks.
                    I hope someone could inspect those attached bin files and tell if they are valid.
                    Thanks.
                    • antas
                      • Jul 2014
                      • 148
                      • Ireland
                      #130
                      Hello. I need you guys, to help me. I'm looking EEPROM dump for Samsung model: LE32R87BD. Model code: LE32R87BDX/XEU.
                      Mainboard: BN41-00813B-MP1.0 Panel: LTA320WT-L07
                      Thank you in advance.
                      • pawan007
                        • May 2018
                        • 7
                        • india
                        #131
                        Samsung UA46F7500 software file need
                        • 1HandyDud
                          • May 2018
                          • 5
                          I guess there is no hope here...
                          • kevinm34232
                            • May 2012
                            • 1884
                            Is there a tutorial on dumping/flashing eeprom chips and the software/hardware needed?
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              #134
                              Supplied by DannyX
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                #135
                                Software Screen TV SONY KLV- 32S550A 1-878-659-11
                                Submitted by Hosin0
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  #136
                                  Software Screen ATA LE32D1
                                  Submitted by HosinO
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    #137
                                    Originally posted by dick_barton
                                    Supplied by DannyX
                                    https://www.badcaps.net/forum/showpo...&postcount=139
                                    TV details
                                    • pawan007
                                      • May 2018
                                      • 7
                                      • india
                                      #138
                                      Samsung ua40f6400 software need
                                      • pawan007
                                        • May 2018
                                        • 7
                                        • india
                                        #139
                                        Samsung ua32es5600r software need
                                        • PROTOTYPE-1
                                          • May 2018
                                          • India
                                          #140
                                          I need firmware for LG 26LD310
                                          Can someone please send me the link to download this firmware.
                                          Or I have this link but I am not able to register so can someone please download and send this to me.
                                          I will be very thank full to you.
                                          http://**************/dump/lcd_pdp_t.../246-1-0-34765
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
