Eeprom dump thread!
This is a sticky topic.
  • alhootalhoot
    • Apr 2012
    • 7
    Re: Eeprom dump thread!
    More files
    • Hamie
      • Apr 2014
      • 1383
      Originally posted by turkay06
      please try..
      This is just a copy of the file I uploaded on page one of the thread. It's for a 32" not a 40"
      • alhootalhoot
        • Apr 2012
        • 7
        Thanks for your reply. I'm attaching the file i've read from the SPI flash chip with the fault (no display on screen), hope someone can see or compare it.
        I have tried re-flashing the same file back on the same chip and on another (new) chip, but fault remains. Also tried fitting a chip from a 50" Digihome tv and as expected worked but with some issues like inverted picture and un-steady picture (flickering).
        • beastaS
          • Apr 2018
          • 13
          #124
          Looking for one for Samsung UE55F9000STXXU. Any leads?
          • jones
            • Jan 2012
            • 23
            #125
            looking for, apex LE4643T, mainboard t.ms3391.a3b eeprom file
            thank you
            • 1HandyDud
              • May 2018
              • 5
              Hello forumers and cheers to all!
              I am hoping to find software for LG 42LF11UA TV North American market.
              I believe there's no problem with power board and or T-Con, the problem is either Mstar (IC100) chip or its corrupt software. I was able to de-solder FLASH chip and read it out/scan for bad blocks. If you could kick me in the right direction and/or throw some software for this model, I would be much appreciative of your generous contribution.
              Thanks.
              • 1HandyDud
                • May 2018
                • 5
                On a side note regarding this LG TV set, the main board appears to be dead and there's no indicator lights, however XTAL 12Mhz is alive and I was able to simulate backlight turn on, so inverter is also good. There's a short period of activity at power on (plug inserted into AC outlet) on BIOS EEPROM chip data lines, so maybe it needs re-flashing too. I could post dumps of those chips here for your review.
                Thanks.
                • sordids999
                  • May 2013
                  • 2161
                  • uk
                  #128
                  Has anyone got the firmware for a LOGIK L32HED13A T.MSD309.B81C
                  Backlight working but nothing else remote sensor is working but no display
                  • 1HandyDud
                    • May 2018
                    • 5
                    Thanks.
                    I hope someone could inspect those attached bin files and tell if they are valid.
                    Thanks.
                    • antas
                      • Jul 2014
                      • 148
                      • Ireland
                      #130
                      Hello. I need you guys, to help me. I'm looking EEPROM dump for Samsung model: LE32R87BD. Model code: LE32R87BDX/XEU.
                      Mainboard: BN41-00813B-MP1.0 Panel: LTA320WT-L07
                      Thank you in advance.
                      • pawan007
                        • May 2018
                        • 7
                        • india
                        #131
                        Samsung UA46F7500 software file need
                        • 1HandyDud
                          • May 2018
                          • 5
                          I guess there is no hope here...
                          • kevinm34232
                            • May 2012
                            • 1884
                            Is there a tutorial on dumping/flashing eeprom chips and the software/hardware needed?
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #134
                              Supplied by DannyX
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #135
                                Software Screen TV SONY KLV- 32S550A 1-878-659-11
                                Submitted by Hosin0
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #136
                                  Software Screen ATA LE32D1
                                  Submitted by HosinO
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #137
                                    Originally posted by dick_barton
                                    Supplied by DannyX
                                    https://www.badcaps.net/forum/showpo...&postcount=139
                                    TV details
                                    • pawan007
                                      • May 2018
                                      • 7
                                      • india
                                      #138
                                      Samsung ua40f6400 software need
                                      • pawan007
                                        • May 2018
                                        • 7
                                        • india
                                        #139
                                        Samsung ua32es5600r software need
                                        • PROTOTYPE-1
                                          • May 2018
                                          • India
                                          #140
                                          I need firmware for LG 26LD310
                                          Can someone please send me the link to download this firmware.
                                          Or I have this link but I am not able to register so can someone please download and send this to me.
                                          I will be very thank full to you.
                                          http://**************/dump/lcd_pdp_t.../246-1-0-34765
