Eeprom dump thread!
This is a sticky topic.
  • jimbofz
    • Apr 2013
    • 539
    • uk
    #1481
    Re: Eeprom dump thread!
    it seems that if the chip is blank it shows
    recognition error
    i am now able to write to chip
    but it only took a few seconds to write is that normal?
    i expected it to take more time?
    • lotas
      • Jan 2016
      • 4578
      • Russia
      #1482
      Eeproms are written quickly, but there should not be a recognition error, most likely you have not recorded anything.
      • lotas
        • Jan 2016
        • 4578
        • Russia
        #1483
        Detect chip?
        • jimbofz
          • Apr 2013
          • 539
          • uk
          #1484
          heres what has loaded and a pic of how ch341a is configured
          • lotas
            • Jan 2016
            • 4578
            • Russia
            #1485
            Everything seems to be correct, click on the check.
            • jimbofz
              • Apr 2013
              • 539
              • uk
              #1486
              data and buffer the same
              so it looks good ill try it and let you know if it works
              thanks again for all your help
              • lotas
                • Jan 2016
                • 4578
                • Russia
                #1487
                Ok!
                • jimbofz
                  • Apr 2013
                  • 539
                  • uk
                  #1488
                  Originally posted by lotas
                  Ok!
                  same symptoms
                  well at least i know eeprom is not causing the fault
                  original post phil pus6162/05 dated 6.4.22
                  trying to find replacement mb for this 65inch model
                  is proving to be headache
                  thanks for all your help lotas
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    #1489
                    Originally posted by luzmina
                    jimbofz: in those Chinese tvs, if the only issue is no sound the problem is the sound amp, make sure the sound IC has power before replacing it, if no sound after replacing it then the issue is the microcomputer.
                    thanks for your post ,
                    i have made a note of the sound o/p ic problem
                    sadly my fault is dead but all supplies ok no sby light
                    • nitsuga
                      • Dec 2013
                      • 12
                      • mexico
                      #1490
                      Do you have the eeprom dump for RCA DETG185R? How can I post a new thread
                      • lotas
                        • Jan 2016
                        • 4578
                        • Russia
                        #1491
                        What's the problem with the TV?
                        What is your motherboard number and what is the panel (matrix) number?
                        You can read the data (dump) from your eeprom and post it here.
                        • nitsuga
                          • Dec 2013
                          • 12
                          • mexico
                          #1492
                          the problem is only red light standby, don´t turn on. Panel HD 18.5" RCA, model DETG185R motherboard CV3393BL-C
                          Do you have Dumps of this motherboard? not necesary that brand
                          • nitsuga
                            • Dec 2013
                            • 12
                            • mexico
                            #1493
                            Is it posible to modify this dump in order to flip the screen ?
                            • lotas
                              • Jan 2016
                              • 4578
                              • Russia
                              #1494
                              Try
                              • nitsuga
                                • Dec 2013
                                • 12
                                • mexico
                                #1495
                                Thank you so much! You are a genius.
                                I wonder if you can change the panel in this firmware, Mainboard CV3393BL-C original panel is HV236WHB-M00 but I need the V236BJ1 panel,
                                the reason is that I need to flip the image, or how can I flip image? Service mode don´t work
                                • nitsuga
                                  • Dec 2013
                                  • 12
                                  • mexico
                                  #1496
                                  Try
                                  Thank you so much! It works
                                  the reason is that I need to flip the image, or how can I flip image? Service mode doesn´t works
                                  • lotas
                                    • Jan 2016
                                    • 4578
                                    • Russia
                                    #1497
                                    Why does the service mode not work, or do you not know the code how to enter it?
                                    • nitsuga
                                      • Dec 2013
                                      • 12
                                      • mexico
                                      #1498
                                      I can enter and modify but the changes disappear when I turn off the TV
                                      • Rajnhl
                                        • Oct 2018
                                        • 94
                                        • India
                                        #1499
                                        there must be function to save changes. try with ok or (>) arrow button or vol/channel + button.
                                        • BigPete
                                          • Jul 2012
                                          • 69
                                          • New Zealand
                                          #1500
                                          LG 60PB6600 Bin
                                          IC100
                                          24C256
                                          NZ version
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            Yesterday, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
