Eeprom dump thread!
This is a sticky topic.
Re: Eeprom dump thread!
Ok., Yes, your dump was badly damaged.Comment
accent tv lcd
viewpia ld-22ieb6 lc-22ieb6 main av l* 22iex6 rev1.4
main: p070l22m2e8 070922
cpu : MST97889ALD-LFComment
I put the Emmc dump for a SONY XBR-65X810C in the link below, the file uncompressed is 15GB, I do not think I can uploaded in this forum a file of that size. Any question post it in this thread.
https://drive.google.com/file/d/14UL...usp=share_linkComment
I need help of this,I need a dump of SONY LCD TV MODEL:KLV-32R402A SER.NO.4180751 pleaseComment
Need a bin dump for my Insignia NS-46l240a13 6MF01001C0 (569MF1101A) which I'm trying to resurrect. It's MX 25L1606L[or L,E,D?]M2I-12G Flash is all FFs. Sorry if it has been posted but I couldn't find the dump using local 'Search'.Last edited by VladC; 03-08-2023, 02:11 AM.Comment
Try.Attached FilesComment
Since I could not find a dump for Insignia NS-46l240a13, I upload a dump for Insignia NS-32l240a13 instead. I lifted it from (almost) the same mainboard which I bought to replace. Should work on both models. Hope it'll help somebody.Comment
But your panel diagonals are different, post your native dump (if left) from NS-46l240a13, I'll fix it for you.Comment
Picture looks like the right size though. Maybe this info is stored in the T-con (original). I suspect there's a problem inside the glass. The original dump is not available, the flash is dead.Comment
No, in the firmware for a specific panel, remote control, backlight current, ... is located on the motherboard.Comment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... - Loading...
