Eeprom dump thread!
This is a sticky topic.
  • MF ELETTRONICA
    replied
    Originariamente pubblicato da MF ELETTRONICA Visualizza post
    ciao lotas ho scoperto che il problema รจ nella nand la tv lampeggia e non si accende se ti mando il dump della mia nand puoi vedere se lo risolvi? grazie
    Provalo, puliscilo dagli errori di bit...
    https://drive.google.com/file/d/1utt...-rVkhZ3E9/view
    ho provato questo file che mi hai inviato credo lo hai modificato? ma non funziona non ricordi?
    English ???
  • lotas
    replied
    Originally posted by MF ELETTRONICA View Post
    lotas can you give me a hand? please
    How can I help, what do I need?
  • MF ELETTRONICA
    replied
  • MF ELETTRONICA
    replied
    I tried lotas but it doesn't work.... only thing is I didn't clean the bits.... sorry how do I clean it from the bits??? but I think it doesn't work
  • lotas
    replied
    hi lotas i found the problem is in the nand the tv flashes and does not turn on if i send you the dump of my nand can you see if you fix it? thanks
    Try it, clear it from bit errors...https://drive.google.com/file/d/1utt...-rVkhZ3E9/view
  • lotas
    replied
    if you open a new page and paste the copied link it works
    Ok, it worked.
  • MF ELETTRONICA
    replied
  • MF ELETTRONICA
    replied
    yes do it like this copy link and open page and paste link you will see that it works otherwise send me your email
  • lotas
    replied
    http://www.mfelettronicasestri.it/DEADfile/MT29F4G08ABAEAWP@TSOP48.rar
    I attach the link to the nand file if you can take a look thanks
    I don't have access to this resource, please upload it to another file hosting service.
  • MF ELETTRONICA
    replied
    i left link above nand can you check it out Lotas? thanks
  • MF ELETTRONICA
    replied
  • MF ELETTRONICA
    replied
  • lotas
    replied
    I have the t56 programmer and I use xgprog
    It's clear, as dump was considered, click on status reg. and you will see in the window where there will be checkmarks, that's what your spi flash is currently set to.
  • MF ELETTRONICA
    replied
  • MF ELETTRONICA
    replied
    ho il programmatore t56 e uso xgprog
  • lotas
    replied
    sorry lotas how do you read a status reg of the eprom?
    The eeprom does not have a status register, but the spi flash does. When reading a dump from the spi flash, the programmer should show which status register is installed. What kind of programmer do you have, if CH341A, then what program do you use for it?
  • MF ELETTRONICA
    replied
  • MF ELETTRONICA
    replied
    I tried it but it doesn't work, the TV keeps flashing but it doesn't turn on, the red light flashes
  • MF ELETTRONICA
    replied
    sorry lotas this is already ready do i have to change the status reg? in case can you tell me what the status reg is thanks
  • lotas
    replied
    ok lotas yes I sent you as you asked me tv model screen model and main number I'll send you everything again here
    tv model
    screen model
    and motherboard model
    I only have this dump.
