Eeprom dump thread!
This is a sticky topic.
  • RRice25541
    • Nov 2015
    • 47
    Re: Eeprom dump thread!
    nop still not working,
    I can put the code from an Emerson ELEFW328 on the board and the tv will come on fine all functions work,, except that i have to go into the service mode and change LVDS_ODD to LVDS_EVEN to correct the image..
    also the image is upside down..
    I couldn't find a way to change the model info, actually i never saw the model number listed anywhere
    couldn't find a way to flip the image in there anywhere either.
    The code from the original eeprom and the corrected eeprom you uploaded will allow the tv to come on but there is no image
    • lotas
      • Jan 2016
      • 4451
      • Russia
      #1202
      So it's not the firmware of the Element ELEFW505 (the problem is in the board itself)
      I don’t understand what it means to β€œput the code from Emerson ELEFW328”, do you mean rearrange the SPI Flash itself with firmware from one board to another?
      What is your panel? Number of your panel (matrix).
      • RRice25541
        • Nov 2015
        • 47
        If i take the code from the elefw328 and write it to the eeprom using the VGA connection from my RT809F programmer, the tv works fine except for the image being upside down.
        the panel is V500HJ1-RX01
        • lotas
          • Jan 2016
          • 4451
          • Russia
          #1204
          ELEFW505 has Full HD panel and ELEFW328 HD Ready. In service mode, you can not flip the image (mirror...)
          • RRice25541
            • Nov 2015
            • 47
            so the problem is the code from the ELEFW505
            • lotas
              • Jan 2016
              • 4451
              • Russia
              #1206
              The ELEFW505 dump is working, most likely it is not native, someone before you programmed a dump from another TV model there.
              • antas
                • Jul 2014
                • 148
                • Ireland
                #1207
                Originally posted by antas
                Could I get a USB firmware update for:
                TV: Walker
                MB: 17MB110P
                PB: 17IPS62
                Panel: VES315WNDA-2D-N12
                Thank you very much in advance
                Or even dump file, please?
                • RRice25541
                  • Nov 2015
                  • 47
                  that's very possible , I have been getting a lot of tv's lately where the owners have monkeyed around with them before they bring them in for repair.
                  so it's very possible they tried a firmware from another unit or something..
                  i guess the only way to know for sure is to get an actual dump from a working unit
                  • lotas
                    • Jan 2016
                    • 4451
                    • Russia
                    #1209
                    There is a Dump ( SPI Flash MX25L1605 ) from CROWN 32289T2SM (17MB110P, VES315WNDA-2D-N12), but there is no NAND dump, do you need it?
                    • antas
                      • Jul 2014
                      • 148
                      • Ireland
                      #1210
                      Yes, please?
                      • lotas
                        • Jan 2016
                        • 4451
                        • Russia
                        #1211
                        Ok
                        • antas
                          • Jul 2014
                          • 148
                          • Ireland
                          #1212
                          Ok
                          Thank you
                          • antas
                            • Jul 2014
                            • 148
                            • Ireland
                            #1213
                            Thank you
                            Unfortunately... Tv not working with this dump...
                            Any more ideas?
                            • lotas
                              • Jan 2016
                              • 4451
                              • Russia
                              #1214
                              17mb110p Dumps.
                              • RRice25541
                                • Nov 2015
                                • 47
                                ok so i think? i found the issue with the element, but I'm not 100% sure.
                                I'm hoping someone can help with some panel pinouts..
                                I don't think this unit has the correct panel type, maybe there's no difference, i don't know
                                but i think the correct panel type should be V500HJ1-PE8 and not the currently installed panel V500HJ1-XR01
                                I cannot find panel info on either of them
                                • antas
                                  • Jul 2014
                                  • 148
                                  • Ireland
                                  #1216
                                  17mb110p Dumps.
                                  Thank you very much. I'll try them.
                                  • mazloum
                                    • Sep 2012
                                    • 499
                                    • Lebanon
                                    #1217
                                    Hi, I need dump for hyundai tv HY-LED39E9300
                                    TP.VST59S.PB813
                                    THANKS
                                    • lotas
                                      • Jan 2016
                                      • 4451
                                      • Russia
                                      #1218
                                      TP.VST59S.PB813
                                      THANKS
                                      Post your non-working dump here, I'll fix it.
                                      • mazloum
                                        • Sep 2012
                                        • 499
                                        • Lebanon
                                        #1219
                                        https://www.mediafire.com/file/s9y29...90615.BIN/file
                                        thanks in advanced
                                        • lotas
                                          • Jan 2016
                                          • 4451
                                          • Russia
                                          #1220
                                          Did you spell the TV model correctly - "HY-LED39E9300"?
