Eeprom dump thread!
This is a sticky topic.
  • Steve007iii
    • Aug 2021
    • Costa Rica
    #1001
    Re: Eeprom dump thread!
    i need firmware for RCA 32
    Board: TP.MS3393.PB855
    • lotas
      • Jan 2016
      • 4655
      • Russia
      #1002
      What's the problem with the TV?
      Post your non-working firmware dump here.
      • Steve007iii
        • Aug 2021
        • Costa Rica
        #1003
        TV starts normally when put in Smart mode TV shows this ...
        TP.MS3393.PB855
        I need the firmware if anyone has them please
        ⚠ This Firmware is damaged ⚠
        Non-working firmware dump: https://www.mediafire.com/file/pm7ri...6S-SM.BIN/file
        32 inches
        modelo: RCA32A16S-SM
        • lotas
          • Jan 2016
          • 4655
          • Russia
          #1004
          Your software is fine, I cut off the eeprom now try to write it down
          if it fails, replace the SPI Flash with a new one.
          • lotas
            • Jan 2016
            • 4655
            • Russia
            #1005
            TP.MS3393.PB855
            32 inches
            Does the TV itself support Smart?
            He then had to have NAND or EMMC memory.
            • Steve007iii
              • Aug 2021
              • Costa Rica
              #1006
              NAND GODDAMN!!!
              it also has an android subsystem
              Not everything is lost
              someone in this forum was asking for this firmware for this board, there it is tested and working
              Originally posted by javox
              hola , me prodran ayudar con el firware de la pantalla cobia TP.MS3393.PB855 se los agradecere mucho. salu2
              Originally posted by aquilesy
              Hi, please your help, I need eprom dump for TV RCA Model RC4001-A board Nro TP.MS3393.PB855
              32 inches
              Model: RCA32A16S-SM
              https://www.mediafire.com/file/5r88m...nches.rar/file
              • lotas
                • Jan 2016
                • 4655
                • Russia
                #1007
                The firmware on your TP.MS3393.PB855 is ok, you need to look for the usb firmware on the android module or somehow enter recovery and do a reset.
                • medoali
                  • Jul 2020
                  • cairo
                  #1008
                  i hope some one can help
                  i need dump for Soniq L32V12A 32" LCD
                  thanks
                  • medoali
                    • Jul 2020
                    • cairo
                    #1009
                    thanks
                    main board ST306PT-T7
                    • giosat
                      • Jul 2021
                      • 5
                      • italia
                      #1010
                      Ciao
                      Tv lg47le5308
                      Main. Eax61766102(0)
                      Pannello lc470EUH
                      • Öğretmen27
                        • Oct 2019
                        • 36
                        • TÜRKİYE
                        #1011
                        Zenon ZN-AHD-5016 software
                        Zenon ZN-AHD-5016 software is needed. 25L12835F used. Fault: The device is stuck in the text zenon. There are all voltages.
                        Mainboard: GM8210-AHD-16CH
                        Flash ıc: 25L12835F
                        • zanskis
                          • Mar 2016
                          • Lithuania
                          #1012
                          hi.
                          i need emmc dump
                          sony
                          kd-49xe8096
                          main
                          1-981-326-12
                          (173633712)
                          GN3TR
                          thank you
                          The TV turns on and shows only the SONY logo.
                          I found
                          KD-55XF7596
                          KD-43XF7596
                          nothing changes, after resetting it needs to be refreshed via usb, and again only the SONY logo
                          • shuma66
                            • Aug 2021
                            • Egypt
                            #1013
                            Originally posted by Snazzysmith
                            Sorry didn't make notes on board number.
                            Please I need LG 42LB5RT eprom firmware
                            • shuma66
                              • Aug 2021
                              • Egypt
                              #1014
                              ٍٍSony BRAVIA® KDL-40EX500
                              System Software Update (version 1.514)
                              May Be Useful and Help
                              • cheeky2
                                • Dec 2012
                                • 337
                                • uk
                                #1015
                                Originally posted by bboykes
                                hi anyone got digihome 40272sm eeprom Vestel 17IPS71
                                You give the model of the power supply without giving any details of your screen or your main board. Unlikely anyone would be able to help you with the lack of information supplied.
                                • shuma66
                                  • Aug 2021
                                  • Egypt
                                  #1016
                                  Thank you
                                  • Shotgun25
                                    • Feb 2014
                                    • 90
                                    JVC LT-50C550
                                    UK model 55" TV
                                    Screen - V500HJI-PE8
                                    PSU - TV5001-ZC02-01
                                    Main - MSDV3255-ZC01-01
                                    TCON/Panel - Innolux V500HJI-XRME1 / V500HJI-PE8
                                    NAND - Toshiba TC58NVG1S3HTA00
                                    From a working TV that had LED backlight strips replaced.
                                    No password, 2 part rar.
                                    • Retrocomputer
                                      • Aug 2012
                                      • 47
                                      • Italy
                                      #1018
                                      Hi! I need the dumps for a cheap Trevi TV.
                                      Model DTV-2522CI
                                      Main HK-7050-CI-V3.04-B
                                      Panel M215HW01
                                      Don't actually care if it's Trevi branded or not, I just care if it works for watching TV.
                                      Thank you
                                      Davide
                                      • lotas
                                        • Jan 2016
                                        • 4655
                                        • Russia
                                        #1019
                                        Originally posted by retrocomputer
                                        hi! I need the dumps for a cheap trevi tv.
                                        Model dtv-2522ci
                                        main hk-7050-ci-v3.04-b
                                        panel m215hw01
                                        don't actually care if it's trevi branded or not, i just care if it works for watching tv.
                                        Thank you
                                        davide
                                        Токаї ltl-1902e hk-7050-ci-v3.04-b
                                        • Retrocomputer
                                          • Aug 2012
                                          • 47
                                          • Italy
                                          #1020
                                          First of all, thank you so much!!
                                          There's just one thing bothering me... The dumps you sent me are from a 19" TV, whereas mine has a 22" panel. Is it ok anyway?
                                          Thank you
                                          Davide
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
