Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4649
    • Russia
    #1141
    Re: Eeprom dump thread!
    Originally posted by luzmina
    Hi, I need the bin file for Magnavox 55ME314V/F7 A4GR1MMA, panel U4DR0XH. I have the DUMP file but is corrupted, I am using the BIN file for the DS3 but I got inverted picture. Thanks
    Post your non-working dump here, I'll try to fix it.
    • luzmina
      • May 2015
      • 17
      • US
      #1142
      Here it is. Thanks
      • lotas
        • Jan 2016
        • 4649
        • Russia
        #1143
        Here it is. Thanks
        Try this Dump.
        • luzmina
          • May 2015
          • 17
          • US
          #1144
          The fixed file works!!! but the picture is still inverted, same as when using the 55ME314V/F7 DS3 file, Thanks
          • lotas
            • Jan 2016
            • 4649
            • Russia
            #1145
            Here you need to try to enter the service mode through the remote control (you need to know exactly what code to dial on the remote control) and change the "mirror" item to ON or OFF.
            • mnjoao
              • Feb 2022
              • 14
              • portugal
              #1146
              good afternoon, along with the dump that works
              thanks
              • mnjoao
                • Feb 2022
                • 14
                • portugal
                #1147
                thanks
                • Storyteller12
                  • Jun 2020
                  • 624
                  Originally posted by Cantv
                  Hello , some one can share with me the EEPROM DUMP FOR Samsung tv UN60H7150 . Thank you in Advance .
                  I tried to read the eeprom for you but was unable to. Tv does work and has no problems at all.
                  For some reason this eeprom wont read. I tried a few others and they all read no problem.
                  Is there a trick to reading this one?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #1149
                    Firmware needed please for a polaroid p43d300fp
                    lcd panel VES430UNDA-2D NI2
                    MAINBOARD 17MB110P 23397404
                    • yokoono
                      • Apr 2010
                      • 488
                      #1150
                      For me in the archive is mb110 not 110p. If you want you can try.
                      https://files.fm/u/ve6hh359y
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #1151
                        Thankyou i will give it a try is it best too remove the ic and programe it that way using a ch341a
                        Edit just downlaoded the file i tried to extract it says no archive is either unknown format or damaged i have tried downlaoding it twice
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #1152
                          Changed to a diffrent pc downloaded files ok if using a ch341a which files do add? i have never really used a ch341a before thanks
                          • yokoono
                            • Apr 2010
                            • 488
                            #1153
                            I checked. The archive is good. Use another unzipped or newer version. Installation is done from the stick not with CH341.
                            Do you know the installation procedure for Vestel electronics?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #1154
                              I picked two sets up yesterday for free both seem too have firmware issues, i have just ordered remotes for both sets so cant try the firmware until remote comes.
                              please can you explaine the update procedure step by step and i will give it ago i have 1gb and 2gb usb memory sticks so hope that will be ok. Thankyou for your help.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #1155
                                • yokoono
                                  • Apr 2010
                                  • 488
                                  #1156
                                  You need the remote control for installation. The installation is done with the OK key.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #1157
                                    Hopefully remote will come either today or tomorrow, what format do i need too wipe usb stick with and could you please tell me the procedure i will print if off for future refrence thanks.
                                    • yokoono
                                      • Apr 2010
                                      • 488
                                      #1158
                                      1. Format a stick with FAT32
                                      2. Unzip and put the 4 files directly on the stick
                                      3. Insert the stick into the TV
                                      4. Press and hold the OK key on the remote control
                                      5. Plug in the TV
                                      6. The TV's stby LED flashes slowly and then quickly. Now release the OK key
                                      7. Wait for it to finish. It may take 5-10 minutes.
                                      If after this operation the remote control is no longer useful, use a programmable one or a Vestel one.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #1159
                                        5. Plug in the TV
                                        Thank you i will try it once the remote arrives.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #1160
                                          Hi remote came and mainboard will not take the update at all i just get a brief flash of backlight at power on ( i do have a diffrent mainboard that uses the same panel the tv powers on and works ok) i cant keep this board in the set as is missing some ports like scart rca plugs extra hdmi port but board swap proves psu and backilights work fine so must be a fault on main bga ic i guess.
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
