Eeprom dump thread!
This is a sticky topic.
  • Denis J
    • Jul 2021
    • 17
    • FRANCE
    #1061
    Re: Eeprom dump thread!
    Thank you very much Lotas, I will test it
    • Denis J
      • Jul 2021
      • 17
      • FRANCE
      #1062
      Hello Lotas,
      I'm sorry the recovery software has no action on my TV. I still have the red led flashing
      • lotas
        • Jan 2016
        • 4639
        • Russia
        #1063
        Originally posted by Denis J
        Hello Lotas,
        Try this dump VESTEL 17mb82-1a "22"
        • cheeky2
          • Dec 2012
          • 337
          • uk
          #1064
          Looking for usb firmware for Toshiba 37RV635DB for 2.1.77.2
          Toshiba links that used to be working are now no more! It looks like there are only supporting the Vestel sets only with a chat service or email.
          My set doesn't always come out of standby with side controls or remote control. I know this is firmware related issue as with the 42XV635D however I have this firmware but will not work on my model!
          So any help would be appreciated.
          • lotas
            • Jan 2016
            • 4639
            • Russia
            #1065
            Toshiba FW 2.1.77.2
            • cheeky2
              • Dec 2012
              • 337
              • uk
              #1066
              Thanks Lotas for looking I have just tried it and unfortunately it doesn't update just like the copy I have (from a German forum a while back).
              I suspect that this maybe be as a result of regional variations to the software that Toshiba implemented.
              If I find a solution or the software I will update it here.
              • Retrocomputer
                • Aug 2012
                • 47
                • Italy
                #1067
                Originally posted by lotas
                Токаї ltl-1902e hk-7050-ci-v3.04-b
                Just to report after I tried: the Tokai dumps didn't work, as the Tokai panel is 1366x768 whereas mine is 1920x1080. The grunkel one did the job, now it seems to not freeze up anymore, unfortunately though the remote seems to be unable to communicate with the tv.
                is it possible that with the Grunkel SPI file flashed it doesn't recognize the original Trevi remote anymore?
                Thank you!
                Davide
                • lotas
                  • Jan 2016
                  • 4639
                  • Russia
                  #1068
                  Thank you!
                  Davide
                  Yes, the coding of the remote control has changed, now you need a remote control for "grunkel" or pick up a universal remote control.
                  • Denis J
                    • Jul 2021
                    • 17
                    • FRANCE
                    #1069
                    hello LOTAS,
                    I flashed the U10 and u12 eproms with the 17MB82-1A software (EN25q64; BIN ET en25q16; BIN) that you generously provided me and then I put the USB key with the vestel 17mb82-1A Recovery software USB program. When switching on the television, the LEDs of the television and of the USB key flashed quickly and at the same speed. A few minutes later the led of the USB key changed to fixed and the led of the television continued to flash more slowly and the TV still does not start. Do you have a solution for my problem.
                    Thank you
                    • lotas
                      • Jan 2016
                      • 4639
                      • Russia
                      #1070
                      hello LOTAS,
                      Thank you
                      Hello, why did you install usb recovery after firmware 25q64 and 25q16, your TV also did not start, you all tried the firmware for this chassis that I posted?
                      • Denis J
                        • Jul 2021
                        • 17
                        • FRANCE
                        #1071
                        Hello lotas,
                        Yes all tried and the TV still does not start
                        • lotas
                          • Jan 2016
                          • 4639
                          • Russia
                          #1072
                          Hello lotas,
                          If the problem persists with all the firmwares, the problem may be different: dc / dc converters, processor ..., try writing to new spi flash 25q64 and 25q16.
                          • Denis J
                            • Jul 2021
                            • 17
                            • FRANCE
                            #1073
                            I also think that the problem is elsewhere although all the tensions are present and correct. I also replaced the two eprom u12 with the same reference and u10 with an EN25F32
                            • lotas
                              • Jan 2016
                              • 4639
                              • Russia
                              #1074
                              And also, how did you update using usb Recovery software, write in detail, maybe you did not do it right.
                              • Denis J
                                • Jul 2021
                                • 17
                                • FRANCE
                                #1075
                                I extracted it from the RAR file and put on a stick formatted in fat32 put in the usb socket of the TV turned off. Then press OK on the remote control and switch on the TV.
                                The U10 and U12 eproms I loaded them with an EZP2019 programmer from aliexpres
                                • lotas
                                  • Jan 2016
                                  • 4639
                                  • Russia
                                  #1076
                                  Unpack the file with the "pkg" extension to the root directory on a usb formatted in fat32, deselect TV (remove the plug from the socket) insert usb, hold down the OK button and without releasing it, supply power to the TV, as the leds flash, release the OK button.
                                  • lotas
                                    • Jan 2016
                                    • 4639
                                    • Russia
                                    #1077
                                    VESTEL 17MB82-2, 17MB82S, 17MB82-1A - Recovery Software (USB)
                                    REVIEWS:
                                    • cheeky2
                                      • Dec 2012
                                      • 337
                                      • uk
                                      #1078
                                      A schoolboy error I made!
                                      I bought another board for the TV which even had an earlier version of software on it, so updated the firmware up to 2.1.77.0 using the method of just plugging the usb formated with fat and which upgraded fine.
                                      Then tried upgrading to the latest 2.1.77.2 . So decided to get the timer out to time the 10seconds wait for releasing the buttons (THIS IS CRITICAL OTHERWISE IT WILL NOT UPDATE ) and the purchased board started to update after about 5 seconds or so.
                                      So tried with the original board in the TV and first attempt failed after waiting 10seconds. So tried it again this time waiting slightly more than 10seconds (around 11-12seconds before releasing the buttons). I was almost about to give up on it after about 15-20 seconds waiting and then the two leds lit up and started the upgrade process
                                      So my fault was that I was impatient in waiting the 10 seconds or so after pressing the two buttons and releasing them. then decided that it wasn't going to upgrade but it did after a little wait.
                                      So pleased to say it was resolved and now will sell the updated board back on ebay for some profit As these TV's rarely get updated and the firmware from Toshiba has been withdrawn.
                                      • Cantv
                                        • Oct 2021
                                        Hello !! i am looking for the DUMP File (.BIN) for Samsung UN60H7150 . Thank you
                                        • kasper_sky
                                          • Nov 2021
                                          • Türkiye
                                          #1080
                                          Hi
                                          Telefunken
                                          Model No:48TF6520 48''
                                          S/N:7867819 700147
                                          PNL:23407779
                                          VBAZ:20273463
                                          Firmware Please ?
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
