Eeprom dump thread!
This is a sticky topic.
  • Retrocomputer
    • Aug 2012
    • 47
    • Italy
    #1021
    Re: Eeprom dump thread!
    Hi! I need the dumps for a cheap Trevi TV.
    Model DTV-2522CI
    Main HK-7050-CI-V3.04-B
    Panel M215HW01
    Don't actually care if it's Trevi branded or not, I just care if it works for watching TV.
    Thank you
    Davide
    • lotas
      • Jan 2016
      • 4535
      • Russia
      #1022
      Originally posted by retrocomputer
      hi! I need the dumps for a cheap trevi tv.
      Model dtv-2522ci
      main hk-7050-ci-v3.04-b
      panel m215hw01
      don't actually care if it's trevi branded or not, i just care if it works for watching tv.
      Thank you
      davide
      Токаї ltl-1902e hk-7050-ci-v3.04-b
      • Retrocomputer
        • Aug 2012
        • 47
        • Italy
        #1023
        First of all, thank you so much!!
        There's just one thing bothering me... The dumps you sent me are from a 19" TV, whereas mine has a 22" panel. Is it ok anyway?
        Thank you
        Davide
        • Farasa
          • Jul 2016
          • 47
          • South-Africa
          #1024
          Hi..
          I'm looking for firmware for a JVC 50 inch led tv...I don't have a number but a board number
          Chassis:Jug7.820.1222
          Cpu. :MSD6328 BXA-Z1
          Panel. :T546hb01
          54T07-c02
          Any help will be appreciated
          • Farasa
            • Jul 2016
            • 47
            • South-Africa
            #1025
            Anyone have this file
            • cheeky2
              • Dec 2012
              • 336
              • uk
              #1026
              Unlikely to get a response where the model number of the TV is omitted.
              • Retrocomputer
                • Aug 2012
                • 47
                • Italy
                #1027
                Thank you
                Davide
                No ideas about this? Or the best thing is just to try?
                Thanks!
                • lotas
                  • Jan 2016
                  • 4535
                  • Russia
                  #1028
                  Thanks!
                  Try, only save your dumps. First try spi flash (EN25F80) to check
                  Here is another 22
                  • Rajnhl
                    • Oct 2018
                    • 94
                    • India
                    #1029
                    Thank you
                    Davide
                    if resolution is same than it will work.some settings like mapping may be needed in service menu
                    • bader
                      • Sep 2021
                      • United Arab Emirates
                      #1030
                      Thanks a lot
                      • Amazig
                        • Jul 2021
                        • 10
                        • Portugal
                        #1031
                        Re: nevir :nvr-7409-43hd-n
                        good night
                        does anyone have the dump of this tv,
                        main board: tp.s506.pb801
                        display: HV430FHB-N40
                        the TV only changes the color of the LED monitor, from red off to green on, and the only thing that does
                        thanks to anyone who can help even with an idea
                        thanks.
                        Last edited by SMDFlea; 09-20-2021, 07:12 AM. Reason: https://translate.google.com
                        • andrewc
                          • Apr 2015
                          • 18
                          • australia
                          #1032
                          Anyone has Sony 65W850C dump file?
                          • Rajnhl
                            • Oct 2018
                            • 94
                            • India
                            #1033
                            Originally posted by Amazig
                            boa noite
                            alguém tem o dump de este tv,
                            placa principal : tp.s506.pb801
                            display : HV430FHB-N40
                            o televisor só muda da cor de led monitor ,de vermelho desligado ao verde ligado, e a única coisa que faz
                            obrigado a quem pode ajudar mesmo com uma ideia
                            obrigado.
                            check back light
                            verifique a luz de fundo (google translation)
                            • Amazig
                              • Jul 2021
                              • 10
                              • Portugal
                              #1034
                              Hello
                              thank you rajnhl; I've already checked the bottom leds; everything working; now an information; I received the bin file to update via usb, will it be possible to record on the chip, because the tv does not turn on!
                              thanks
                              • tech9pc
                                • Sep 2021
                                • 48
                                Hi does anyone have firmware for RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008
                                I got a Version 1 CV3458H-A, 7.T3458HA1000.0003 off ebay for 30.00 and popped it in and board works but about every 20 or 30 minutes tv loses input signal and have to flip HDMI source than back to get picture up again. Probably from not being the same board as original which has lost its HDMI port signals won't work.
                                They are practically identical. Anyone know if I flash the 7.T3458HA1000.0003 board with the 7.T3458HA1000.0008 firmware should work? Thanks for any help.
                                Board BD_CV3458H_A_10
                                Panel LC650RU1A
                                • andrewc
                                  • Apr 2015
                                  • 18
                                  • australia
                                  #1036
                                  I need dump file for Sony 65W850C please.
                                  • Rajnhl
                                    • Oct 2018
                                    • 94
                                    • India
                                    #1037
                                    Hello
                                    thanks
                                    plug usb drive and connect to power .
                                    • Farasa
                                      • Jul 2016
                                      • 47
                                      • South-Africa
                                      #1038
                                      Hi..
                                      I'm looking for firmware for a CHANGHONG LED55A4000 55 inch led tv...
                                      CHANGHONG LED55A4000,
                                      Panel. :T546hb01
                                      54T07-c02
                                      • ducky29
                                        • Dec 2015
                                        • 370
                                        • Europe
                                        #1039
                                        Hi..
                                        Panel. :T546hb01
                                        54T07-c02
                                        Post a picture from the back of your tv.
                                        • Farasa
                                          • Jul 2016
                                          • 47
                                          • South-Africa
                                          #1040
                                          Ok Ducky29
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
