Eeprom dump thread!
This is a sticky topic.
  • petehall347
    • Jan 2015
    • 4426
    #841
    Re: Eeprom dump thread!
    Originally posted by Joseph melville
    do you still need the eeprom?
    might do . have other problems now as had accident with the led board and shorted the fet .
    • antas
      • Jul 2014
      • 148
      • Ireland
      #842
      Anyone, can help me with EEPROM, please?
      Looking for:
      WALKER WPS3219SM
      Mainboard: 17MB211S
      Chip: Winbond 25Q16JVSIQ
      Panel model: VES315WNDB-2D-N21
      Thank you in advance...
      • yokoono
        • Apr 2010
        • 481
        #843
        Try (Toshiba). Main 17MB211S panel VES315WNDB-2D-N21
        • antas
          • Jul 2014
          • 148
          • Ireland
          #844
          Tryied this just now.
          Unfortunately, it doesn't work on this model... Thanks for trying to help me...
          • yokoono
            • Apr 2010
            • 481
            #845
            Try this too. It is for 17MB211S panel VES315WNDS-2D-N21. If the image is returned I have the profile saved for fixing.
            • antas
              • Jul 2014
              • 148
              • Ireland
              #846
              Not working....
              • yokoono
                • Apr 2010
                • 481
                #847
                I think there is another problem on the motherboard. Most often problems with dc-dc converters or processor. See also if the flash memory is powered by 3.3v.
                What are the symptoms of television?
                • antas
                  • Jul 2014
                  • 148
                  • Ireland
                  #848
                  Thanks for coming back to me.
                  Yes, there are 3.3v on the chip (EEPROM). 12v and 5v are on the board as well.
                  The red light is on and blinking 2 short times in intervals.
                  Backlight is working OK.
                  • yokoono
                    • Apr 2010
                    • 481
                    #849
                    Don't confuse eeprom memory with flash memory !!!. They are different. See what memory you rewrote. The software is for flash memory, spi.
                    • antas
                      • Jul 2014
                      • 148
                      • Ireland
                      #850
                      Sorry. I rewrote Winbond 25Q16JVSIQ (U135)
                      • yokoono
                        • Apr 2010
                        • 481
                        #851
                        How does the defect manifest itself?
                        • antas
                          • Jul 2014
                          • 148
                          • Ireland
                          #852
                          TV not turning ON. When you turn TV ON, RED light up and stay solid. When you push ON button, RED light blinks 2 times and stay solid. Then blinks 2 times again and stay solid. And does this all the time.
                          PS.: Backlight I checked with the mainboard from Panasonic TV. Backlight working, just can't turn ON the TV.
                          • yokoono
                            • Apr 2010
                            • 481
                            #853
                            Heat the processor to 230 degrees for 1 minute and see what it does.
                            I think the motherboard has a hardware issue not a software one.
                            You can replace the memory with another new memory.
                            • antas
                              • Jul 2014
                              • 148
                              • Ireland
                              #854
                              Heated for 1 min at 230 degrees. Nothing. Still the same problem...
                              Do you mean I have to replace Winbond 25Q16JVSIQ with new one?
                              • yokoono
                                • Apr 2010
                                • 481
                                #855
                                Try. Rewritten. I have no other ideas.
                                • antas
                                  • Jul 2014
                                  • 148
                                  • Ireland
                                  #856
                                  Thank you so much for your time, buddy
                                  • jose almeida tavares
                                    • May 2011
                                    • 8
                                    #857
                                    Blaupunkt w40/58j-gb-fhcup-eu memory dump
                                    Hello, i need memory dump for this tv. the mather board t.msd309.8b 10304 and panel lta400hm07. thanks.
                                    • Farasa
                                      • Jul 2016
                                      • 47
                                      • South-Africa
                                      #858
                                      hello everyone i just got this set in...37 inch Telefunken chassis... 40-1MS82D....I dont have the panel number...I need the dump for this board....thanks in advance
                                      • Farasa
                                        • Jul 2016
                                        • 47
                                        • South-Africa
                                        #859
                                        Anyone at home
                                        • Rajnhl
                                          • Oct 2018
                                          • 94
                                          • India
                                          #860
                                          Originally posted by Farasa
                                          Anyone at home
                                          try this one
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
